It's the same. On my schematic i'm not using that 10ohm resistor between C and E of transistor. I told you my problem is that on pin 17 for uC i'm not detecting any change so the uC is not triggering the transistor from my point of view.
I have tested also your software from post #277 wich is very nice.
I must say i'm totally begginer in microcontrollers.
Try exchange pin 15-16
Didiet
I suppose your are suggesting to xchange de pins of LCD who powers the backlight but they are correctly connected as the backlight works when i'm shorting C-E of transistor.
a simple test code to see if the backlight pin is working
this turn on off every 5 sec
Code:
$regfile = "m8515.dat"
$crystal = 8000000
$hwstack = 32
$swstack = 10
$framesize = 40
config portd.7 = Output
Portd.7 = 0
'Test code
do
Set PORTD.7
wait 5
Reset PORTD.7
wait 5
loop
From Danzup code, pin 17, it should be 5V (Logic 1) when power on and 0V when power off. Did you measure it?
Didiet
Didiet
Thanks Farmtech your code was very helpful. I had problems hardware and software. After installed Farmech's test soft i noticed even i have 5v on pin 17 still no light so i decided to replace BC517 Darlington with a simple generic NPN and it worked.
After this with Danzup sofware still no light but gues what Danzup invited me to his home to solve the issues (we are living in the same are but never met each other) and we solved almost everything. Remained the final test: sound In sound OUT to see how it perfoms.
Danzup is a great guy ! 😉
Hi, atupi! We'll find your problem easily - just point me to the software your'е using - I also remember I've found small inconsistencies in the program while debugging mine (earlier in this thread). So, what's your firmware?
Oh, sorry, you've got that really fast 🙂 What was the real issue, apart from damaged transistor?
P.S. Danzup is a great guy indeed!
The issue was that in software was another pins from another port used for backlight and connections.
Here is my work in progress. I recicled a box from an old sattelite receiver but it fits well a would say.
Software is not fully functional but after all hardwork a will meet Danzup again for fine tuning.
Schimbarea surselor o fac tot din encoder insa incep sa cred ca ar fi mai elegant sa folosesc cele 2 taste SUS-JOS neutilizate de pe panoul frontal.
The analogic part of PGA is made using two simple shunt regulators using LM317 as CCS.
Hi there.
I have a SymAsym Amplifier now ready working and I want to implement the feature to change the volume and source over a Remote and Rotate Knobs.
The Volume and Source should be displayed through a LCD or OLED-Display. I have read some of these pages but I dont know If I understood it right.
1.)Is there any Groupbuy to this?
2.)Is this controller changing the sound in any way?
3.)What is the "last" and "best" version to this?
4.)Did I understood it right that the Software-Part is OpenSource (This would be awesome)?
5.)Is this also realizable with a AT90USB162 Dev Board?
Is there any other Project/Board that you would recommend more if I want a Volume (maybe with motorized Potetiometer) and Source selection with remote and Display. I could program an AVR.
Thank you very much for your help in advance.
Greetings from Tschöhrmany!
Ron
Ron
Ron,
We still have boards available for sale at vicol audio : Webshop
In R-2R version the controller is transparent - not changing the sound.
We are using a custom firmware, therefore this in not opensource.
Tibi
Tibi
1.) No there is none such .I have posted the integral documentation such as schematics and firmware , and everyone is free to do what he wants and wherever project wants.Hi there.
Ron
2.)There are 2 projects that do not change the sound : that project with alps motorized Potetiometer and that with r2r Volume do not change the sound !
Regardless what other on world said : all cmos/mos/jfet/PGA2310/TDAwhatevernumber Volume have their own sound , like I say dog barks and bear just passed by .....
3.) Project are as their are and if the readers are not confortable with microcontrolers and audio and electronics in general maybe this projects are nor for them .The best I think is the r2r and/or blue velvet motorized Potetiometer project ( but I say that again here).
4.) Yes i posted firmware for everyone to edit / use / modifie as inteded by everyone, there are the source code attached so no problems about modifiing .
There are by years a lot of projects made by exactlly as you requested ,but never posted here , only in romanian forum where now have dissapeared after the server that hosted forum crashed , but if you need : atmel Atmega + LCD + 4 source input select + one motorized Potetiometer + IR i will post this project here . Just say and i will find that schematics and firmware in my backup files and post here.
5.)As it seeems that AT90USB162 is supported by AVR BASCOM it means that this chip can be used on project but there are some modification that must be done . I do not own such chip so it is up to you to try . Say what project do you want to do and I will try to help .
Also : if anyone want to try some Group Buy I will support them with advice and help but cannot make and will not intend to open GB by myself.
Regards ,
Dan Zup
Errata : the firmware of R2R controller is not Open , and I will not post firmware for that controller, as that one is specially designed and writted for Vicol Audio : check webshop
there are ready mounted and programmed R2R Volume controller.
click on Shiga infrared remote and it takes me to a CD product..............We still have boards available for sale at vicol audio : Webshop
For VC scroll down to DanZup R2R / Shunt vollume controller LCD display version.
Tibi
My finalized preamp in a recycled sat receiver box:
and inside where needs a bit of cable management. Pga 2311 powered from some shunt regulators and a hotrodded DCB1 (Pass&Salas)
I think this topic should be moved to the Vendor's bazaar because parts of it are clearly commercial. If not, the Hypex Ncore topic should be moved back to Class D!!!!!
Help with software
I'm using the software attached and something is wrong and it drive me crazy.
So, when i'm using remote control (Philips) i need to press the key on the remote several times per second to have effect and is very annoing.
This situation is the same if i want to change volume or input.
If i press the button and keep pressed nothing happening.
Please note i'm noob in avr programming.
Thanks!
Adrian
Thanks!
Adrian
- Analog Line Level
- Yet another Volume controlers and source selections
