high voltage capacitors
Hi all,
I have just completed the first run test on a Tubelab SE, I now want to upgrade the quality of capacitors in the power supply side of the project. I currently have a Panasonic 47uf 450v (the model i am unsure of ?CE(m)) and the other is a Rifa 150uF 450v in parallel with an ASC 87uF Motor run. I have used high grade caps throughout, only I think the Panasonic and Rifa may be letting the team down, any ideas? Suitable replacements?
Cheers
