Discrete Opamp Open Design
Today with availability of semiconductor coolers temperature can be kept below minimal ambient temperature level, but it creates moisture problem.
Wait a minute. 😡 What is with you?
First heating above ambient temperature, now cooling below ambient temperature.
I think I’ll have some pills. 😀 (Do you know the waveform of the “positive vibrations”?)
I know about the good name of the Tomsk Polytechnic Institute, but I was not aware of this exciter.
George
Scott, have you looked on such potentials from copper to solder to copper or copper/gold plating to solder to copper ? (moving coil cartridges and microphones circuits)
George
No such research is a lot of work and I asked one of the foremost experts in the field and he told me he knew of very little (none?) literature on thermocouples with thin different metal films.
I actually made little knots of gold and aluminum 1 mil wire by hand. 😀
May I ask why?
Is this true for bipolars too?
(Lack of basic knowledge. I thought I knew that lowering temperature lowers every kind of semiconductor noise )
George
I think it's because the electrons didn't bring any thermal underwear, so when they get to the wall, they are not able to climb over it..but shiver instead..
At really low temps, the pn junctions actually become insulating to the tune of 3 to 30 volts depending on diffusion profile.
jn
(Just before the beer)
I am surprised.
First by the answer from the experts, as I think that this problem had to be addressed in microcircuits and micromachines.
Second by the “research” on copper/solder/copper. What research? This is the most common/dominating case of electrical connection in electronic circuits for how many decades?
How many?
George
coluke, what kind of distortion figures/spectrum do you get OPEN LOOP?
Did a very quick and dirty test (see attached sample FFT run): open loop THD @ 1kHz, ~0dBV into 30 ohm is about 0.15%, only low order. OLG is about 62 dB, OLBW > 20 kHz. Closing the loop at 10 dB gain leaves you with about 50+ dB of loop gain midband - closed loop THD should be even less than the figure I've got (0.0013%). Actually the baby is quite polite 😀, but probably a slightly better layout is in order... :xeye:
Ciao,
L.
George,
Thanks and raise that glass. No funny faces I can't see where they are coming from.
On the question of copper lead copper or similar metals aren't any of these going to be a basic battery through simple electrolysis of dis-similar metals? One of the metals is going to give up atoms or electrons to the other isn't it?
May I ask why?
George
It may lower noise, but lower temperatures definitely lowers conductivity of semiconductors, and at lower temperatures they just won't turn on. The whole physics and chemistry of silicon and germanium, energy levels, conductivity and how it's affected by doping and temperature is explained in just about every textbook on transistors (now, "semiconductors" to include ICs/chips). At the time (when I was in college, late 1970's) I thought it was pretty useless information unless one was going to work in a transistor manufacturing plant, but now my opinion is one can't have too much knowledge.
