Some LM317 Bode Plots
Here are some bode plots of a Fairchild LM317 under various conditions:
Wikipedia said:
If the transfer function is a rational function with real poles and zeros, then the Bode plot can be approximated with straight lines. These asymptotic approximations are called straight line Bode plots or uncorrected Bode plots and are useful because they can be drawn by hand following a few simple rules.
Wikipedia disagrees. It says the Bode plot can be approximated by straight lines, not that the Bode plot is straight lines. The Bode plot is the full curvy plot, as I said.
it does not look exceptional.
What is does show is that much thought needs to be implemented to get good test jigs. Then these good test jigs can reveal lots that we do not yet know about our circuits.
eg. Hamon divider
I only recently discovered that this existed. It is so simple to implement and yet is capable of far greater accuracy than I can ever achieve by ANY other method. And that is not an exaggeration. I can get +-20ppm with a few hours work on a two stage Hamon Divider giving 1:10:100 ratios that I just cannot get otherwise.
Mr Hamon is brilliant.
Your schematic shows that you too can think and devise tests.
That's excellent stuff! IMO, the 317 is remarkably capable if used properly. There was an old paper/datasheet that showed the noise peaking if the output cap esr was too low. It's on line somewhere, though I can't locate it right now. No doubt it was part of your inspiration!
One thing the test setup here shows is how useful transformers can be, solving isolation and common mode problems that would otherwise be difficult.
+1, very interesting.
The paper Corad refers to is 'Understanding and reducing noise voltage on 3-terminal regulators' by Erroll Dietz, National Semiconductor. Appears as an appendix in Bob Pease' excellent book on' Troubleshooting analog circuits'
This is the graph:
Could we extrapolate from that graph and guess that 47uF to 220uF may be even better at attenuating that noise peak?
Alternatively, would adding a low ohm resistor in series with the cap bring down the peak?
Which would be more effective?
100uF with the intrinsic esr of a standard commercial electrolytic, or a 22uF with 0r1 added to damp the peak.
What do you think?
Would Jack's test rig show this? I am trying to interpret the last pic in the series (47uF+1r0). What is it showing us?
