45 tube amp schematic
Hi everyone,
I'm looking for a good 45 tube amp schematic. I need it as simple as possible (so I can spend more on the single pieces), but with a high-end sound since it will stay with me for a long time to come. I'm thinking on using emission labs tubes, those with an output of 3.5w per channel. My idea is to use it with a dallas II horn, so with the fe206en (spl 96dbl).
I courrently own an unison research s2 that drives fonkens with the ff125wk. A good amp, but not exactly what I expected it to be..so I need to move on and build one on my own since I can't/ don't want to spend thousands of euros on an amp..
Thanks in advance for any help!
Ervin
Hi Ervin,
Sounds like a nice plan - great and simple amp, nice speaker with good sensitivity. I think this is an excellent direction.
You weren't happy with your existing set-up - do you know it isn't the fault of the speaker ? In trying to change both the speaker and amplifier together you are not allowing for the possibility that only one of them is failing to meet your needs. The FF125WK is not a speaker I've heard, but I have heard other Fostex small cone drivers and I don't find them to be satisfying for all types of music, in fact due to some awkward peaks in the treble response I've found them a bit limiting. Not all fostex drivers are like that but the frequency response of the FF125 makes me nervous.
Perhaps you should go ahead and build that larger speaker you are interested in first. Let it break-in and try it with your existing amplifier. I believe it will give you another valuable piece of information to refine your plans.
I'm unfamiliar with the 45, but I read that the emission labs version is very pricy, it's perhaps not viewed by some as a true 45 but a new type with much higher output power. If you use this tube you may be very happy with it, but you would also be locking yourself in to a very specific tube with a single source of supply. If this is the amplifier to last a lifetime that is a risk.
I am planning to build a nice SET too, and I'm thinking that I should base it around the 2A3. There are many old NOS tubes to spend money on if you like, there are also many newer tubes on offer from different manufacturers. it will also give you those 3.5W you are looking for.
As for a schematic - there are so many to choose from and many of them are simple. I'm currently considering a simple design based on what I believe is used in Don Garbers Fi 2A3 amplifier. it's a direct coupled design, a single high-mu triode directly drives the 2A3. others on this forum with more experience than I can probably suggest other options with different advantages.
The Simple45 that Bigun linked to is the precursor to the TubelabSE, which makes a nice 45 based amp with mosfet followers. Tubelab sells the PCB's and if you pick up a power transformer with several secondary taps, you can build/modify the design to run 45's, 2A3's, or 300B's.
The 5842/417a front end is sufficient to drive any of the above power tubes using the followers.
Of course you could build it P-2-P as well......
Hi Bigun,
Thank you for the help. It's not that I don't like the unison research, it sounds really good, but I don't think it is an amp worth all the money you need to buy it. I've always been in love with the unison research since I've been interested in hi-fi, so buying one it was like touching heaven for me!..but after listening to a small amp with some cheap el82 made by a guy (total cost around 200 euros), my reaction was to take my unison research and throw it out of the window! Of course my amp sounds better, but only a 10% I would say! But remember that we are talking about an amp that costs 9 times less than the unison.. (and it's not a question of tubes, since I have 2 old telefunken and also 2 svetlana C, some of the best el34..).
'So, if an amp made with ultra cheap componenets can sound almost like an 1800 euro amp, why don't build an amp with good parts on my own?', this is what I thought, and here I am, asking for some help.
Referring to the emission labs tubes maybe you are right, it would be a better idea to use 'normal' 45 tubes.
Ervin
Hard to do better than this
Direct coupled, choke loaded, parallel feed, 45 with a constant current source on the driver. Meets your criteria for simple, and quality definitely depends on the choice of components. Note that direct coupling means you will be working with stacked (high) voltage. Not a good build for the easily distracted. What amp is?
Even though the design is going on 15 years old, all the parts are still available. CCS's may be had in kit form from several suppliers.
single
Thank you all guys!
After spending half a day on internet searching for a schematic and looking at your posts I've come to a conclusion..I want to build the amp buy jeff korneff. 🙂
From what people says it seems to be a really good amp.The only problem now is to find the schematic..does anyone have it?😀
Does anybody have any experience with this amp?
Ervin
Please consider this schematic, it has exceptionally good performance for what it is, and uses the easy to get hold of EL84 and ECC83 tubes with fairly low complexity. Distortion is also low too, with negative feedback implemented. It is not my own schematic, but over the last 5 years or so I have built about 4 or so of these amplifiers with excellent results. It is not my own schematic and I can't quite remember where I got it from but it really is an excellent design and fits right into your requirements.
I recommend using a fullwave bridge rectifier and paralleling the windings ( or by replacing the EZ81 with a couple of 1N4007 diodes snubbed out with 10nF caps), so you can use higher value caps for power supply and lose the inductor for a 470R resistor, the first pair of filter caps this way should be 220uF (1&2) and 3 should be 100uF. This way the 470R resistor in series with the psu can be swapped out for just a 150R resistor.
I've heard some other SE EL84 amps before, no feedback ones mainly, but this circuit seems to beat them all in terms of performance (or at least sounds miles better, the incorporation of negative feedback really helps), if you use a silicon rectifier then you can make some good improvements to the PSU, which is what I did when I built my second one. It's a nice simple circuit with good performance for what it is.
The trick is to invest a good percentage of your budget in the output transformers.
I built the amplifier point to point and used moderately priced JJ Tesla valves. I used a 25w chisel tipped soldering iron. I wouldn't recommend a small/low power iron for point to point, 25w is the optimum power in my opinion 😉.
