I planning to start my first DIY audio project, and wants to build a Class D amp.
I thinking about buying two L15D, which I understand is pretty good, from reading here on this forum.
Is these the correct ones?
300W IRS2092 IRFI4019H IRAUDAMP7S Amplifier kit L15D | eBay
Also I guess I need a speaker protection circuit, is this OK?
2-channel Stereo Speaker protection board LED assembled | eBay
The PSU I will build from an 2x33V 250VA trafo and two 10000µF capacitors, and two 10A rectifier bridges I have laying around.
Does the PSU need to be regulated?
Do you guys think this will be OK? Do I need some more?
Believe L15D-PRO is same amp but with speaker protection relay built in.
you mean this?
New L15D-Pro 300W 4ohm IRS2092 IRFB4019 Mono amplifier kit | eBay
is there any other difference?
It will be ok...but no need to use two bridges..the amp works gr8..and all the best
thanks.
my mistake about the rectifiers :-S
But do the PSU need to be regulated?
do NOT buy!!! These "kits" are just too cheap, you'll find their riddled with fake components and will blow up in your face.
Thats true so far....there kits can be bought for testing purpose and with some little alteration it can work fine...
thanks.
A non stabilized power supply will do the job no need to regulate....and the kits are for short term use...they dont have much capacity to handle the heat with that small heatsink...so just look at how there kits works and in thru there measurements and then build your own amp as per your needs...all the best buddy
Other people on the forum rate the Zoe & Along supplied Ebay LJM kits/built up modules just fine so is the criticism aimed at this one seller or at LJM kits in general? After all LJM is a forum member and the L15D kits have excellent reviews on this forum. What is the evidence leading to this criticism? Also, class D is supposed to dissipate little heat, the heatsink size appears comparable to other class d amps and they are only single channel.
- Class D
- First audio DIY project: Class D amp from modules
