3EF PCB
I am just a beginner in the field of electronics, which I can only draw the pcb, and even then as a novice.
i hope u understand my bad english.
regards.
thnks engel...,yes i will share my work of 3EF pcb if it's corrected by anyone who is in this capacity,nice work riff
i hope you were the answer to all waiting for 3EF pcb for share😀
regards.
bridge mode(point A and B)
regards,
mj777
This what apex said, refer to post #74Point A and B for bridge mode.
regards,
mj777
Hai Riff,3ef VAS without limiter
i hope sir mile can correct this.
regards
you can use half of 5532 for balance input
Hai Riff,
Like on this sch 🙂
mr mile,please help me with your power i want to built apex b500tef with travo 20a 45-0-45 vac,what anything that must i change for speaker 18'x2x4ohm can move maximum?
Hi Nazirdigi
greetings how did you put the values of components this is sir apex commercial design
warm regards
andrew lebon
warm regards
andrew lebon
hi apex sir,
check this page and read post no (60).
http://www.diyaudio.com/forums/soli...t-amplifier-irf540-irf9540-6.html#post2179519
u replied 2 year before.
Apex sir we waiting for thishi apex sir,
when u are sharing this pcb layout?
for VAS look like from
100W Ultimate Fidelity Amplifier
Hello Nazirdigi did you try this circuit.There is a fault in component value of negative side ofswitcing circuit. I have corrected it and is working fine since 6 months.
which circuit vedmitraa?
- 900W H-class PA Amp with Limiter
