Box colourations - really ?
StigErik ... I'm trying to understand why you feel that boundary reflections are less affected w/dipole ... ? Aside from the polar pattern, you still have a much stronger rearward projection than w/monopole ... no? My listening, in an untreated room @ elevated SPL's, doesn't follow along with this.
... unless the "every room" has acoustic treatment?
maybe you are referring to the +1khz response and not the bass? In my previous smallish untreated room I had annoying results in the highs. That's where the distance from the walls really play a role I feel..
@Markus, thanks for clarifying, I am not that big! 🙂
@markus76
I am trying to do the same measurements as you did.... but I have nothing but bad luck here. First I had to replace the power supply on my CLIO computer...it was dead. Good thing I have spares, this computer is 20 years old. And now it seems like the harddrive is defective... again. I can do the measurements, and they confirm my claims, but I can't save them. This is embarrassing, I know
@markus76
Hi Stig (?), Eric (?),
Thanks for the effort. You could save them to a USB stick or use one of the online storage providers, e.g. DropBox or Skydrive.
OK, have the measurements. First a little about the room, speakers and measurement points.
Here is the room layout. I have four H-baffle woofers, placed as shown below. The listening distance is very short, only 1,5 meters. At the rear end of the room there is a diffractal diffusor.
The nine measurement points are all done 1 meter above the floor, spread out in a 100 by 50 cm square around the main listening position.
There is no room EQ on the measurements.
All are done with MLS in Clio, 160 ms time window, and there is no smoothing at all.
Here are all nine measurement together.
What happens at the positions that are farthest from the center, is that the Left and Right woofers starts to cancel each other because of the phase difference. This is seen above 100 Hz.
Also note that this is the woofers only, with crossover at 200 Hz.
And here's a comparison between left and right channel, taken in the main listening position.
As you can see, there are small deviations above 100 Hz, probably caused by the fact that the room is not entirely symmetrical, and I was also present in the room when it was measured, which do affect the result.
thanks, but I feel Markus won't be happy.. 🙄
1hz precision he asked for!😉
I realize we actually have a very similar speaker placement, I thought your subs were much closer to the corners, and far away from the mains, hence my question a few days ago about the audibility of the localization at 200hz..
I did have monopole subwoofers a few years ago. It was impossible to find a position where the response was anywhere near how the dipoles measure. I don't have those subwoofers anymore, but I replaced one with my bass guitar cabinet, a Seas L26ROY in large vented box, and placed in the same locations as the old subwoofers I had. And this is how it measures. No crossover or EQ here.
Thanks fir these but could you use a larger window to increase resolution? Such a short window works basically like smoothing 😉 I've used 1000ms in my graphs.
Could you also please use the same zoom I did (60dB range, 15-200Hz)?
CLIO does not support that. Sorry.
But I did do one sinewave measurement with 1/48 octave resolution. It looked smoother in fact, so the MLS reveals more detail.
