Bass for my soldier
assuming all amps have the same input sensivety.!
first set the red circle settings.
next set the green settings ,details will follow.
x-over @ 18db/oct butterworth
next set the eq at the yellow markings to your "taste".
if you know what you are doing ,you can play around with the dynamic eq marked blue.
when everything running "smooth",you can relax the limiter settings and play with compressor settings.
setting up delaytimes/phase left channel (right channels are off)
step 1 turn the high amp off
step 2 play a sine wave off 150 hz at moderate volume (you can find them on the web)
step 3 reverse phase 180 degr.
step 4 slowly ad delay until the sine wave is the least audible.
also try with phase normal 0 degr.
step 5 reverse phase.
done.
repeat steps 1 to 5 for the high delay/phase
turn off sub amp
sine wave 1500hz
if you are not comfortable with setting up delay/phase,leave all delay/phase settings at default.
it wil probaply sound fine as is.
Yes I am totally suprise
I didn't believe it at first but after my wife and friends explained everything to me and show all the help they get from here i was totally surprise. I had a kool aid smile on my face all night. I didn't know what to do with myself that night.
@ Epa and Oliver
I am out of words and many thanks . I think you guys deserve this cruise that I surprise my wife with more than she does. LOL
I did not get a chance to fully play with the system yet but from what i heard at the party it sounds great. I will have more to tell later.
Got to run we have a plane to catch.
I will be back in three weeks.
:happy1:🙂
Love and kindness
