yes...
Yes, I do think that I addressed that in my post, but to be more clear:
If the sonic changes I experienced during break in were related to the electrolytic caps forming (as I suspect) then it is reasonable to assume that there will be some level of forming that will need to happen everytime the voltage is taken away from the caps. If you have the amps cold, depending for how long, the caps will start to go backwards, and will require some amount of re-forming on power up.
How audible this will be is unknown by me at this point, and would also likely depend on how long the amps are powered down. I have not had the modules here long enough to get a feeling for this, but it seems that some here have not noticed any change with initial break in as well?
We were speaking about warmup not break-in.
Understood. 🙂
I'm not a big believer in break in for audio equipment but did think that it took ~6 hrs for them to settle down. It sounds crazy I know but after putting a few pairs together and testing them this is what I found.
YMMV
Jason
I've ordered the ncore modules based on all the great reports I've read from users. This is a leap of faith for me as I really like Class A amps and particularly ones designed by Nelson Pass (I currently have a pair of First Watt F4s). I've never heard the Claytons you had so I'm wondering (a) if you have heard any of Pass's amps and if so how the Claytons compared and (b) have your ncores usurped the Claytons?
cheers
ian
cheers
ian
Jason
cheers
ian
Yes, I owned the Pass Labs X-1 along with an X-250 before my Claytons which the NCores have replaced.
I had the Claytons for 7 yrs. First M-200's then M-300's.
Not to go too far off topic, but the phenomenon of breakin is often largely the listener breaking in, not the component.
on break in...
Changes in ESR of electrolytic caps have been measured, so no "voodoo" required to understand why it might matter. Not that I do not believe in other break in factors as well, but capacitor forming is a well established, phsyical, measurable, reality.
Impressive that you prefer the nCores over the Claytons, so far I am not sure where I stand versus my Pass X 150.5, there is more low level detail with the nCores, but the tonality of cymbals, bells, etc "seems" to be lacking-to be fair, this is with the modules just sitting out in the open, no case, non-idealised wiring, etc. so I am not drawing any conclusions yet.
That...
Certainly could be the case soemtimes, but not in this situation. The reference (and reference system) was a known quantity, already broken in. Comparisons between the nCore and the reference amp were made, and those comparisons changed as the nCores changed.
I was formerly employed by a high end audio manufacturer, and part of my position involved listening tests of prototype components, I am pretty well versed in making these kinds of comparisons.
So I guess you preferred the Claytons to the x250. Reassuring that someone who is clearly not prone to changing equipment every time a new fad comes along has been won over by the ncores.
How exactly and with what tools did you de-solder the R141?
I have now tried three times and it just won't budge. First i tried just quickly with a cheap 10€ solder iron, not a change. Then i tried with the same iron heating it like half an hour with closed windows etc, no go.
Well, now i bought a proper 100w solder station (Xytronic LF-2000), and tried with 480 celsius temperature. Still no go! This time, I just managed to add little bubbles of solder to the resistor that was on the iron tip.
Well, i did not heat the part for very long, just for 10 seconds max or so. It's almost like the part was welded instead of soldered. Should i just heat the part for longer time? I would not like to break anything. Is the patch of nCores i got using some extra tough solder?
I just added first some tin to one side, then to the other so I got tin on the top. Then I put the iron so I heated both sides at the same time and used a tweezer to push the resistor away. Tadah, desoldered R141!
But was much harder to solder it back but it's doable that too, make sure you save the resistors because you never know if you in the future want to. I taped the resistors in one of the plastic bags to a side of the chassi =)
adding a led illuminated switch...????
I would like to add a so-called "vandal resistant" LED illuminated SPST push button switch to take my ncore from standby to play via the nampon line. The switch I am looking at needs 12V to power the led. Can I take power from the aux power on the SMPS which would be around 11V on my 120V mains to power the LED, assuming it might be a bit dimmer, or will it not light at all due to some threshold requirement? Any input appreciated...Thanks....
Heh, I never really understood all those fancy push-buttons for on/off... IEC with inbuilt button for the win 😉
But then again, I want to hide my setup and not showcase it... that it sounds good is good enough for me 😛
I grabbed a similar switch (LED input rated at 12V) and tested its functionality with a worn-out 9V rechargeable currently giving 8.4V down to 6.5V. I am not sure about the exact voltage at the time, but there was a soothing glow from the LED. You might find the thing too bright at 12V. Try a range of series resistor values if that should be the case, or use a pot and measure the resistance at a suitable brightness level, then go for the closest matching resistor value.The switch I am looking at needs 12V to power the led. Can I take power from the aux power on the SMPS which would be around 11V on my 120V mains to power the LED, assuming it might be a bit dimmer, or will it not light at all due to some threshold requirement?
If I remember correctly the speaker outputs on the NCore should ideally not be on opposite sides. I think Bruno taked about the inductor introducing unnecessary noise into output if that was done.
This may become obvious when my modules arrive but at the moment I don't understand what mean by "opposite sides". Can you explain further?
you should plug the wires like this:
http://www.diyaudio.com/forums/vendors-bazaar/190434-hypex-ncore-430.html#post3045504
I don't think it is 11v @ 120v mains
IIRC the smps has two operating modes - 120v & 240v - so you're back to a nominal 22v aux supply when you have 120v mains
The data sheet says it is proportional to the mains voltage and says Vaux is 16V at 180VAC, 21V at 230VAC and 24V at 264VAC. I calculate a bit less than 11V at 120VAC. This is between Vaux+ and ground. Between Vaux+ and Vaux- it should be 22V. Am I getting this right?
- Class D
- Hypex Ncore
