capacitor rating
Great Question
i have some shizuki motor start oil cap rated 400Vac, wondering if they are safe to take working voltage of 500VDC?
Great Question. I do not know. I know that for fuses and for switches, Usually the AC can be multiple times higher than dc, due to arcing, as for caps, I don't know, aaaaannnddd you are wanting to use are higher voltage too?
Not sure if it is a good idea.
I hope some else can help you 🙂
Btw, you have not advised of its capacity... how many uF or nF is it? What type of circuit are you planning on using it in. Will it be seeing a high current, or low current, will it be audio or electrical work?
Options - options, so many things to consider.
