memphis st1500
time/div .5 time/div 5us
Do you see the same signal on 2 of the 3 pins?
its on all three pins.
Is your scope calibrated? I would expect the peak to peak amplitude to be a bit more? i just did it.
If you look at pin 9 of the TL494, is the square wave very nearly perfect? I'd expect this one to be more square but I don't know if it's your scope or the signal. still the same.
If that's from pin 9, there is a problem with either the scope, the probe or the calibration of the probe to the scope.
In post 20, I asked if the transformer was shorted primary to secondary. You stated that was and stated that you found it but were not specific as to what 'it' was. Is the primary to secondary short fixed?
when i hook the probe up to the calibration on the scope. i get a clean square wave.
it was a solder i think from my desolder pump that shorted the transformer out. its fixed.
