i want to play whatever frequency it is through my guitar or a sine wave generator and make the walls shake and maybe break the sliding glass door.
It's very difficult to calculate and everything in the room will resonate at different frequencies. On a more serious note, serious structural damage can be done and unless you are doing this as part of a demolition i would not advise it.
Your best bet would be to get the sine wave generator (and some ear protection), hook it up to a decent amp and sub/ bass speaker and sweep the frequency untill you hear a peak, probably in the high teens or low hundreds of hertz.
Knock yourself out... I dare you 😀
Adrian
Adrian
resonant frequencies
I'm not sure how far you'll get, other than possible hearing damage. I know those car audio guys find the resonant frequency of their automobile interiors and go to 150-160db+ and still have their windows when its over. Maybe they actually modify/change their windows so they don't break? Which is another thing, you may need the resonant frequency of the glass door and not the room?
Actually, you're most likely not going to need to get loud enough to experience hearing damage...
As posted above, get a tone generator and turn up the volume to moderately loud and slowly sweep the freq upward. You will hear the resonant freqs in the room because things will buzz and at certain freqs the system will seem much louder than at others... That having been said, keep in mind that the response of your ears is most likely not flat but you will be close...
Another option is to use a spectrum analyzer and white noise. This is how we used to tune rooms when I was doing pro sound work. The analyzer will clearly show you the peaks that the room is putting off and has the advantage of also showing you driver interaction as well as whole system interaction.
Lastly, be careful if using a tone generator with the volume too loud. Keep in mind that it's creating a continuous wave and as a result doesn't give the voicecoils in the drivers time to cool. If it's loud and you're sweeping low freqs the bass driver voicecoils will get very hot!!!! BE CAREFUL!!!! I needed a recone on an 18" driver once because I was testing at low freqs with a very large amp and got carried away... Please don't repeat my mistake!!!
This should get you close...
Good luck,
Steve
Good luck,
Steve
The easiest way is to calculate the wavelength of the room--the length, that is--then place a speaker at one end. You can also go for half, quarter, etc. wavelengths.
Ezmeralda's point about the glass is a good one, though. The resonant frequency of the glass will be quite different fromo that of the room, and better damped, as well.
Not that I'm recommending that you collapse your eardrums in this manner.
There used to be a bass rig--the Acoustic 371--which had a small red and white warning label on the back of the cabinet saying that SPL within 10 feet of the cabinet could exceed 130dB. Naturally, I had to try it...
Looking back, I wish I hadn't...
Grey
Grey
Your internal organs will burst first causing fatal internal bleeding. This occurs somewhere between 2 and 5 Hertz.
travis said:can i explode my skull if i find it's resonant frequency?
only if you are lucky.
Brian
If it's a rectangular room, the lowest resonance frequency will be when the longest side of the room is half a wavelength. if l is that size and the speed of sound is c=340 m/s, then the lowest res. freq. is f0=170/l Hz.
I think you'll explode it if you try to solve the wave equation for standing waves inside. 😛can i explode my skull if i find it's resonant frequency?
It possibly can once you realize there are many resonance frequencies.can i explode my skull if i find it's resonant frequency?
For a rectangle room without furniture calculations should be pretty exact but of course reality is different. However it is a nice tool to correlate measurements and theory when you do speaker measurements inside.
Just plug your numbers into the sheet (modes1.xls) and look astounded at all those resonances in your room:
Room Acoustics
Search for "modes1"; its about half way down although it might be best to read it all.
how can i figure out the resonant frequency of my room?
There are simple calculations for that.
Unfortunately, my home is a bit more intricate, so, I don't really have "a room", it's more of "a space". That is totally fine with me!
But, yes, run a sine wave up through the audible frequency range (and sub-audible range), and it'll jump right out at you.
- General Interest
- Room Acoustics & Mods
- how can i figure out the resonant frequency of my room?
