I will test the lay in the near future. No pcb layout in pdf, if you need I can do.Yes Sir.. I like your system.. have you tested the pcb and how about the sound... can you send me the pcb layout in pdf file..? thanks
The scheme is identical to the apex b500, just add a resistor to set the quiescent current output stage, and used an opto limiter АОР124Б. Power supply in the may version of the +-35V .Please share the schematic Sir.. I think your pcb and component litle difrent compare with B500.. how about the max voltage for this amp..?
which the resistor used to regulate the bias current?irwanks B500 with 2 pairs output transistor only for homeaudio
I use 1kohm variable resistor (trimpot) instead of 680ohm resistor. It can increase and decrease bias.
It is hard to find mje 15033 and 15032 in bandarlampung. I use A1837 and C4793 instead of mje 15033 and mje 15032. What kind of project, sir? sorry I only can help soldering if i have time, i can't help much.Yes mr Irwanks.. ..mje 15033 and mje 15032 easy to find in malaysia.... How in Bandar lampung easy to find overthere.? Next time if I back to Bandar lampung I want to make saound system project...
I hope you can help me and join together.. what do you think mr Irwank...?
To what extent is governed measured the idle current? and which the quiescent current put you?I use 1kohm variable resistor (trimpot) instead of 680ohm resistor. It can increase and decrease bias.
hi! diy members in the philippines need also to build b500 somebody can help send me the part's, all the details regarding B500. my add is luisito.cerdenia@yahoo.com tHANK'S in advance 🙂
nice amp sir,may i know what is the rail voltage for this two pair of trannies and part no.sir, 😕thank's
You can get all full information about B500 from page one until this page Sir...
slowly reading Sir... good luck...😉🙂
Today launched its lay APEX, works well, sound is clear, deep, sounding pleased. Just heat up much before the output stage transistors, had to put a small radiator.
The amplifier was tested by a weak power supply capacity was not high, the limiter is not plugged, it is necessary to recalculate it for this amp.
apex;
working b500
good sonics
i'll drink for this one;
cheers
nice work sir, maybe some time we can share a couple of bottles ;-P
andrew cortez from philippines
i still envy to those who manage to get IR2117,😡
but i still have tlo72 step driver to make🙂
thanks to you apex
hi engel,
maybe i can help you with IR2117,
best regards
andrew cortez
nice work Sir and good pcb design so flexible ....🙂🙂
Mr. Dilip Will you please elaborate what you mean by " Demo fail and " "tery again".First learn how to write and show something than only comment.This way dont show your ignorance.VedmitraSharma.
Can somebody tell me is there any chance of using TO3 transistors for b500
i want to know THD values and slew rate of this amp
sir have you tried L6380 replacement for Ir2117,if so, pls share.my add is luisito.cerdenia@yahoo.com ....my b500 almost completed only few parts hard to find here in our place, like mje's.want to build also h900, hope you reply. thank's and more power to you.
MR.VEDMITRAA JI I AM NO COMMENT AND
Mr.Dilip Kumar... What you mean...
- 500W PA amplifier with Limiter
