500W PA amplifier with Limiter
b500
Hi Apexaudio
greetings well i made your triac soft start my torridal has 13swg
in primary 11swg in secondary what must be the 50 ohms resistance wattage i am using TRIAC BTA41 40 amperes is it ok or should i replace with higher ampere triac
warm regards
andrew lebon
Reactions: mihailo
hi everyone!!!...
today i've finished b500 and have mounted in the chasis...😛😛😛
i've tested it today...amp sounded reall good...very good for mids...
very crystal clear audio...very nice highs too...😀😀😀
one should make this amp...
tnx a lot to sir apex for sharing this very good sounding amp with us...
thank you sir...😛😉😀🙂:happy2:
:cheers::cheers::cheers:
this amp deserves a drink...:drink::drink::drink:
:cheers::cheers::cheers: :checked::cheers::cheers::cheers:
Dear Apex,
I am new here and i'm very interested to build this B500, please kindly forward me on :cop: email address removed please PM :cop: the Construction guide, PCB layout and parts list in PDF.
Many thanks for sharring this.
Willy
I have recieved but why can not open sir... have the pcb tested..?
the transistor final only 2 pair right.?
Yes, transistors, two pair. I want to remove this amp 200 watts, I used two pairs of output transistors only. If you need more then 200 watts can be done in the spring mounted on the output transistors.
PCB was made for ease of use in building an amplifier, all the output transistors through wires attached to the motherboard, it is very convenient when placing the amplifier in the body anywhere.
Yes Sir.. I like your system.. have you tested the pcb and how about the sound... can you send me the pcb layout in pdf file..? thanks
