100W Ultimate Fidelity Amplifier
Here vou are...
Hi Apex i am new in diyaudio,I want to build your amplifier in post #144 AX100 please post schematic diagram and what is the minimum and maximum rail voltage of this desing kindly help me.Sorry for my bad English, Thanks in advance
These would be the files needed:
  • spisak dijelova.txt
    spisak dijelova.txt
  • New Text Document.txt
Components Replaced?
Dear sir Apex and other members!
I'm a new audio diyer. After long time read many shematic at here, I decided to build AX-17V2. But in my country (Vietnam), 2N5401 and 2N5551 is hard to find and fake. I can replaced 2N5401 & 2N5551 by BC550 - BC560 or 2SC1815/2SA1015 ? I can get BC550/BC560 & 2SC1815/2SA1015 more easy. I redraw PCB that I downloaded from here, because copper in my PCB I gotten is thin, it can break when I replaced components... It is correct? I redraw a version for diffirence pins of 2SA1015/2SA1815 later.. Thanks for all!
Nice pcb, use 2SA970 and 2SC2240 instead 2N5401 and 2N5551.
viktor1986 has noticed a mistake in a pcb-design: the base of the 2SC5200 is connected to a base 2SC4793,instead to it´s emitor. The lines to B and E of 2SC4793 have switched places,that should be changed.
That is what i have noticed after viktor´s warning,maybe he has seen something more,i don´t know. As far as i have seen that would be the only mistake done here...
