L'Amp: A simple SIT Amp
L'amp CCS- Power Supply Resistor
Hi Everyone,
Why is there only a single 1 ohm power resistor used in the power supply and not four .47 ohm power resistors used like in other amps? I used this single 1 ohm resistor in the Zen 9 (as a short-cut) and the supply voltage dropped by 4-5 volts. Is a voltage drop required?
Thanks,
Vince
hi all , do you want to know who is the dumber of the week? it's me 😀
i have said that putting a 33ohm resistor in parallel with the speaker output had brings more 3D sound and better mids .. i was totally wrong , the better sound is here but my resistor is 12K 2W tantlum 😛 so it is so high that it cannot make any difference in output impedance ..
any idea about what a so high value parrallel resistor could make ? 😕
That could be me.....🙂
that´s why Zen Mod says I have golden ears....😀
after every change I hear an improvement.....😀😀😀
and how does it sound when you parallel a real 33R?
I will try to hold the 33k between my left thumb and the left digital finger and look if I hear any difference....😀😀
thanks for your open words......it is a relief....
sound clean but flatter like too much negative feedbach on a tube amp , perhaps it"s only with my speaker and my thin monobraid speaker cable..
.. generg tell me if you find the same , if not i will join zenmod in his Deaf audiophool beach club 😀
O.k. I will help you Not to get a member of ZMs club.😀
Indeed after some time of hearing I think a value that is better for my system may be a bit higher 68R is my favorite candidate at the moment.
At any case it is possible to shape the sound of the 1H93V in this way a bit in a direction you like.
I am afraid we are all a bit ZM like, in the love of high efficiency speakers,
A clear sign of beginning deafness!😀
ok enough letting go now :shhh:
i ve got a question for the elite of the elite of this thread:
what part of the underneath the 2sk82 actually transfer heat? is the round part most effective or the whole surface conducts heat equally?
because i dont have an appropriate pad with me, i m kind of making one that is easier to make if it doesnt cover the whole surface...
