I know that this is a quote from Dec 2011 that I'm replying to...
... but could two of these regulators, tied in a bipolar manner (with input grounds isolated from output ground; possibly separate transformers/windings for each regulator), be used to achieve a negative output rail?
Unfortunately, Bobken regulator cannot be implemented with negative rails.
this is Paul's design, he corrected the above statement only a couple of posts afterwards, you can use it for N or P
Oh bugger, completely read over that post--thanks for the pointer!
