Aikido 9 pin All in One Build
Ex-Moderator R.I.P.
Joined 2005
in the tube list, at the very end of manual ;)
ups, mine is the mono solo board, obviously with different numbers
in my kit R17 is not related to heaters, but adjust the PSRR 'system'
but I thought at least the numbers in the large tube list would be the same through all versions :confused:
is Broskie not too smart, or being exactly that
at least its definately very confusing
Also, make sure the voltage and value uF are correct...even if the bag is labeled correctly I have had a couple where JB must have been tired or had a few, luckily the last one I did not catch was just one of the heater caps, it was a 47uF 450V instead of the 10,000uF one. Since they were both the same size and type (the black Nichicons) I missed it as well and didnt catch it until the amp was complete and couldnt figure out why my heater voltage was all messed up.
Pic attached...hash mark terminal aligned with printed sleeve for neg terminal.
