>apparently Golden Ears can "listen through"
>these loudspeaker distortions of thousands
>times greater magnitude
It doesn't take "golden ears"
Distortion does not mask distortion.
If a signal is run through 10 distortion producing
stages, (audibly) the differance between no stage
and after stage 1 is near equal to between stage
9 and stage 10 .............
Actually simple harmonic distortion can cancel under some conditions. It is a useful design technique in amplifier stages.
Morinix, that is a good website for showing what we try to do with TOPOLOGY to lower inherent distortion, SO THAT we do NOT have to use so much negative feedback or even zero global negative feedback. Why do we want this? Because there is SOME distortion that may NOT be measurable by normal test equipment that the ear DOES pick up on. I am sure that these 'distortions' exist. There is too much evidence toward their existence.
Hi John, just curious because of the rampant stream of consciousness in this thread. Just lately I come to find this thread that started in part 1 nearly SIX AND A HALF YEARS AGOMorinix, that is a good website for showing what we try to do with TOPOLOGY to lower inherent distortion, SO THAT we do NOT have to use so much negative feedback or even zero global negative feedback. Why do we want this? Because there is SOME distortion that may NOT be measurable by normal test equipment that the ear DOES pick up on. I am sure that these 'distortions' exist. There is too much evidence toward their existence.
![bigeyes :bigeyes: :bigeyes:](https://files.diyaudio.com/forums/images/smilies/bigeyes.gif)
That may be for special planned instances, but in general
distortion does not mask distortion.
This is incredibly unknown !
The (say) 1% produced by an amp can be discerned with
a speaker producing (say) 10% as easily as if the speaker
produced (say) 1% (or 0% for that matter)
(by discerned I mean recognized if switched on/off)
Good to know.Maybe not.
Hmmm, well, enough posters to have this thread in the 1st grade if it was a person.Maybe not. Who cares, anyway?
There's a company that has been testing and categorizing silicon for dc to dc conversion at 77k. Power as well as smart stuff. The purpose of conversion at 77k is to eliminate the warm to cold transition heat loss of very large copper conductors required for 5 or 10 kiloamp operation. If they can use a kilovolt or 2 and drop the current to 50 amps, the refrigeration expense goes down.
John
Never been down there, had a few amps that still worked at 130K or so. Never published the data which is too bad, it was a nice survey of GR noise across several manufacturers over extreme temp ranges.
It did and it was based on an error. (Jan in editing changed a symbol in the schematic which led him solo on a merry trail of errors.) My response corrected that and added a few details.
Read the article, it is quite complete. The technique is being used by two test equipment manufacturers and one resistor maker that I know about.
Next try my article on how to measure distortion in solder joints and audio interconnects.
What happened to the "feedback goes round and round" article?
I believe I specified that the added distortion was of substantially the same character, and a many thousands of times less in magnitude when talking feedback R vs dynamic driver voice coil heating effects
anyone want to bet they can tell 5% 2nd order nonlinearity from 5.01%, or 5% 2nd cascaded with 0.01% 2nd - that 0.0005% 4th sure must stick out like a sore thumb - right?
we might be able to construct test signals that give a IMD products from the above guestimated 4th term that clears the masking threshold - but with music I really doubt it can be heard
and I've still got a couple of orders of magnitude "in my pocket" if you really followed the Z-Foil vs voice coil numbers at all
See my website below- last page about 2/3 rds of the way down. Martin Collums (spelling?) take on the subject from about 20 years ago.
Some laughed, and some claimed they saw the light after that one.
Morinix, you asked me a 'flip' question and I gave you a 'flip' answer.
In all actuality, 95% of anything that the CTC Blowtorch has in it, has been put up here. I just don't publish my more recent schematics of my personal designs. I still make a living giving other companies my designs, and I cannot dilute their value, by giving them away here, completely. Actually, I have been very generous with my input, and will continue to do so, when I get a serious question.
Which LA article? The first one you did was woefully lacking in details, as pointed out by Samuel Groner.
If you read Samuel's thesis you would find many of these measurements with no noise or interferors to explain away, quite an excellent job. There are several ordinary caps and resistors that truely make the distortion not matter.
Thanks, lots of letters too I'll have to print it out for the next trip to the loo.
Not exactly what the article is about Scott, but if you recall what I have shown about it so far in this thread, there are some interesting issues.
As has been mentioned and a few bits of data shown, one very important issue is to be sure that when you take measurements you are measuring the right parameters.
So to evaluate feedback schemes and theory one needs to have a repeatable series of tests that correspond to skilled listeners. That brings up the issue of what is a skilled listener and can they be trained?
I have already pointed out that even finding a switch with less distortion than many components is a very difficult task. So the current comparative listening technique does not rely on a switch!
Now my current article is on power supplies. It was supposed to be a short one but it is coming up on 20,000 words. One of the feedback related issues is how noise causes errors and what kind of errors. Although I have a noise generator (Previously shown here) there is no standard on how to measure noise and it's influence on real world equipment. There are lots of tests going the other way!
So the simple article on feedback has several issues that need to be examined a bit more fully.
But just for you, in any feedback design one must be sure that under any condition such as noise, out of band signals, multiple uncorrelated signals, transients or envelope modulated signals the circuitry does not clip, slew rate limit etc. This is best realized by modest requirements for the feedback.
Clipping and slew are are all part of the design process, plenty of amplifiers with gobs of feedback work fine. I'll remind you xDSL amplifiers operate totally starved on supply current use lots of conventional feedback and have low distortion into 50 Ohm loads at 30+MHz. They also operate in horrible environments (phone cabinets at max allowed heat).
Hi Ed,
would you mind to elaborate bit the right parameters and repeatable series of tests that correspond to skilled listeners?
Thanks,
- Member Areas
- The Lounge
