Vca's
I have no experience with designing these circuits myself, although I have modified them sometimes to make a mixer work more or less normally with a damaged fader.
Besides making the filter time constant as large as possible, you should also try to keep the current throught the wiper as low as possible such that variations in contact resistance have little effect on the control voltage. If you have an RC filter right behind the potmeter and no DC load, the voltage remains constant even when the wiper temporarily doesn't make any contact at all. Besides, with carbon potmeters, any DC current through the wiper should flow into the wiper to prevent anodisation (according to an old Panasonic trimmer potmeter application note).
In normal broadcast use, the lower part of the fader typically gets damaged first because discjockeys tend to shift them very hard from -20 dB to -infinite dB. In that case it is handy to design your circuit such that it goes to -infinite dB when the wiper doesn't make contact at all. My damaged fader modification was to add a 10 Mohm resistor, an RC filter and a CMOS op-amp connected as a voltage follower between the fader and the original circuit. The 10 Mohm resistor would pull the wiper to the voltage corresponding to -infinite dB, but with only a very small DC current.
I'd pick a pot size that would run about a mA, and put a probably 0.1uF to ground off the wiper that would feed the control voltage into the VCA, as a default. Chemical reactions often happen when dissimilar materials are put in contact with each other for extended periods. Back at Tektronix I used to hear the phrase "molecular migration". With enough current flow, a migrated and thereby largely corrupted connection in a switch, a connector, a relay or a wiper in a pot could often be cleaned up, at least temporarily. Too much current in a pot could increase noise. 1mA seems like a good guess as to what might work good. The cap to ground will filter out any wiper noise above some hopefully low frequency, depending on circuit impedances (calculate HZ with R or Z, from the point of view of the cap). 0.1uF seems like a good starting point for that. The cap size is too big when you can sense a delay between knob rotation and VCA gain change. I'm actually building something right now that will be using the Analog Devices SSM 2018T VCA (a 2 to 5 surround sound extractor, very similar to what I think "Circle Surround" is doing) (WAS doing - their product is no longer available as a separate).
