What kind of feedback do you call this?
Yes, actually the distortion is less if you replace the constant current source with a resistor but it really kills the power supply rejection ratio.
I should have been testing at 1 KHz in post one and not 10 Khz, so I’ll continue at 10 KHz.
Yes, but then there is the problem of the current through R1 drifting with temperature as the current is (V1 - Q3Vbe – V3)*R1. That’s another reason why in my first post I had the ccs. It makes things simpler. It dose not matter so much with a large value of R1 but we want to keep R1 very small to reduce dissipation.
Constans (again)
It is even possible to keep both the voltage across the output transistor constant as well as the current through it. This results in a very low distortion buffer stage. I published this idea seven years ago on diyAudio:
http://www.diyaudio.com/forums/soli...ge-const-current-output-fet-2.html#post775787
MikeB showed a version of it with JFETs that provides zero DC shift:
http://www.diyaudio.com/forums/solid-state/70745-simple-low-distortion-jfet-buffer.html#post803157
Even after all these years I never built a real (tangible) version of this circuit.
Cheers, Steven
Inside of an op-amp feedback loop, driving a capacitive load (47nF), with added parts to prevent self destruction.
Now to layout a PC board.
Schematic, Distortion 1KHZ, FFT 1KHZ, Distortion 20KHZ, Current -40C to 80C.
Of course it will probably not work anywhere near these levels when built and probably require some tweaking.
  • HeadphoneBuffer.asc
    HeadphoneBuffer.asc
  • LME49860-files.ZIP
    LME49860-files.ZIP
