Scan-Speak Discovery 10F/4424G / 10F/8424G
Scanspeak Discovery 10F/4424G, 4" Midrange 4 ohm: Madisound Speaker Store
Scanspeak Discovery 10F/8424G 4" Midrange 8 ohm: Madisound Speaker Store
The price is a big turn off. I could have sworn these were around $60 each when I first saw them. Did the neodymium really go up so fast, or was I just dreaming? I sure wish they were cheaper. Why keep using neodymium if it drives cost up so much? On the other hand, the one thing I always want more of with 3" drivers is motor strength.
Cost aside, I thought the results on Krutke's blog looked pretty promising. Looking at Sd, they're really about a 3.5" driver. Has anyone tried these as full-range? Any thoughts on the "coated NRSC fibre glass cone"?
I have a set that will be presented in the Round 2 of the "Subjective Blind Comparison..." thread. The measure very flat - one of the smoothest responses I have measured in any driver. They are very well built and sound excellent. I have some initial measurements in the TC9FD Best Bang for the Buck thread http://www.diyaudio.com/forums/full-range/268626-vifa-tc9fd18-08-best-bang-buck-21.html#post4247669. Right now I am waiting for the highly regarded Visaton B80 to arrive for comparison before releasing the sound clips for Round 2.
I tested the 10F/8424G00.
Specs here:
http://www.scan-speak.dk/datasheet/pdf/10f-8424g00.pdf
It is a special driver so making a box for it is difficult - trying to find something worthy of it. I am basically going to end up with something similar to the FAST setup it currently got tested in. Looking at a short vented TL for the 10F, and an 8in bass driver in either a sealed or tapered vent TL. XO at about 400Hz, miniDSP and bi-amped of course.
..........Cost aside, I thought the results on Krutke's blog looked pretty promising. Looking at Sd, they're really about a 3.5" driver. Has anyone tried these as full-range? Any thoughts on the "coated NRSC fibre glass cone"?
Haven't tried 10F for me will depend which of 10F/8424G00 or B80 looks best in Subjective Blind Comparison round 2 that xrk971 intend later when B80 arrive.
Below interesting links to confirm their data.
Member wesayso share 8424 data from Klang & Tong http://www.diyaudio.com/forums/full-range/268626-vifa-tc9fd18-08-best-bang-buck-35.html#post4250353.
Both 10F/8424G00 and 10F/4424G00 are here go to index at top of thread to see other driver models too and the measurement conditions plus gear used, 🙂 use of translation could be needed ??-????????.
10F/4424G00 measured and at index top of thread see other driver models too and the measurement conditions plus gear used http://medleysmusings.com/scan-speak-10f4424g00-discovery-4-midrange-4-ohm-version/.
