I'm designing a TPA6120 based headphone amp, is there anyone can give me some advice
I'm designing a high-fadely headphone amplifier based on TPA6120, is there anyone can give me some advice?
Here is the schematic I designed.😀
you might look at Peranders TPA6120 project for ideas, pwr pad soldering hints
rather than a independent buffer op amp in front I much prefer a Multiloop topology where a good quality "audio" op amp applies global feedback around the TPA6120 - this improves the performance of both amps in the composite
Walt Jung has written about these multiloop composite amps for audio line driving, check his site, his "Op Amp Applications" book (online at Analog.com)
Thanks for your advice.
I'm interesting of Peranders TPA6120 project.
Could you please provide me some information about it?
5 kOhm is "over-compensation" - since the current feedback op amp feedback R value ~ determines (inverse) GBW, this higher value slows down the amp, may make it easier to stabilize
12 uA could be too big a input current for noiseless, long life for volume pot wiper, OK if driven from a lower Z source
