Hello,
I have a speaker 3 way with the info follow:
Power handling 200W
Impedance 8 ohm
Sensitivity 88db +-3db
Frequency rang 120-18KHz +- 20Hz
2 woofer (full rang ? ) connect series
1 tweeter connected parallel with 2 woofer
I should buy the 3 speaker with impedance total of 8ohm ?
Pat
Power handling 200W
Impedance 8 ohm
Pat
two 4 ohm woofers one 8 ohm tweeter
passive crossover @8ohm
two 4 ohm woofer in series + one 8ohm tweeter in parallel with these woofer give 4 ohm total not 8 ohm.
if i connect a resistance 8 ohm in series with a 8 ohm tweeter and both of them in parallel with these 2 8ohm woofer in series, does it work ?
