If you are looking for a real high sound quality stereo FM audio transmitter at a reasonable price, the VMR6512 is second to none. It's also developed by me in 2011. 380k have been sold till last month. It works from 88-108MHz or 76-108MHz, frequency can be set by button or serial port in 0.1MHz step. Power is high enough to be received at 100 meters away (in open air). Moreover, it even has digital audio interface! Most customers use it in wireless headphone and in car MP3 transmitters.
VMR6512 hifi stereo FM audio transmitter
I don't see any coils or capacitors in the circuit. Is the output just a digitally generated square wave? If so, isn't there a problem with interference from the harmonics? e.g. If you're transmitting at 100MHz, won't there also be significant output at 300MHz etc?
On second thoughts, I suppose the unwanted radiation will be too weak to interfere with TV, Police, ATC or whatever's on the higher frequency (too lazy to look it up).
[ot]
low power transmitters are fun! I think that's about the first thing I made as a kid when somebody gave me my first transistor.
[/ot]
p.s. I bet you can get a lot further than 100m with even a half-decent antenna.
[ot]
[/ot]
There're SMD coils inside the module. The spectrum of this module is very pure since it has PLL circuit. 10mW has no harm to any other applications. The distance could be longer with better antenna, and it depends largely on the snesitivity of receiver.
Yajnas, besides the sound quality, have you ever seen a Taiwan or Chinese clone mp3 FM transmitter with digital audio interface and can adjust frequency, power, pre-emp and mute via serial port? It's not the simple IC like BA1407
Yes we have a assemblyed board.
VMR6512 HIFI Audio Transmition Board - Boards | Kits | Components | Modules | Tools
Maybe a BA1407 (or similar) and a PIC (or Atmel part)?There're SMD coils inside the module. The spectrum of this module is very pure since it has PLL circuit. 10mW has no harm to any other applications. The distance could be longer with better antenna, and it depends largely on the snesitivity of receiver.
- More Vendors...
- Siliconray Online Electronics Store
- Broadcasting level hifi audio FM transmitter
