Subwoofer low end hiss
If you turn the volume control down to zero and the hiss/noise becomes inaudible then that tells you that the power amplifier is adequately noiseless.
If turning up the volume control brings back the noise, then that confirms that something before the volume control is creating the excess noise.
Shorting the inputs will confirm if a bad termination at the inputs is the cause of the excess noise. Did you say that you have 4 inputs? You will need to short all 4 of them using 4 dummy zero ohms plugs, or whatever you have to hand.
If that silences the noise, then remove one shorting plug to hear if one or more inputs are creating the noise.
right I have connected the input to the RH phono as normal, and connected a phono the right hand, and simply shorted it out, it sorts it.
Does that mean I have bad interferance outside the sub then. Shall I just make up a shorted phono would that be adequate, as it does solve it.
