Quick guide on Grounding
Here we go😀
Paulo,
the Disconnecting Network is optional.
Onaudio has shown this optional Network without specifying the detailed arrangement.
Onaudio,
I would prefer that your diagram also included the compulsory Permanent Chassis connection to PE.
Thank you Andrew. Do modify and post 🙂 . Appreciated.
I am hoping that this thread will remove some cob webs when it comes to grounding as well as addressing the real issues that go with it.
Its a free contribution thread.
Where the two filter caps join, you should 'T' off and then star connect everthing. Do not make the junction of the caps your star ground.
When I was young I used to battle with this stuff, now I have it tapped and can build perfectly humless/buzzless audio.
Atleast any wires bearing current such as the speaker returns should in my opinion always go to the center point of the main storage caps and NOT to a secondary star.
My lafet amp does have a secondary star on the drive board where the signal grounds go along with some filter caps, and then a single wire from there to the center point of the main caps, there is no hum what so ever, u have to give it a signal to tell if its on or not.
So having signal and speaker ground sharing the same ground lead is the right way then ?
As in having smaller storage caps on each channel which center point is each channels speaker ground with a 10 ohm resistor between it and signal ground and then three leads per channel to the main psu, is this what your trying to say ?
If yes, then that for sure hum loudly as signal and speaker ground shares the same wires.
The speaker ground must have the same reference as the input signal, otherwise you are treating the difference between these two points as part of the signal. The arrangement shown in the link from post 11 ensures that ripple current feeding the second set of caps gets injected into the speakers. I assume this is not what you want.
Tekko, could you please try a quick sim experiment? With the circuit grounded as you show, could you place a few ohms in the lead going from PCB ground to the PS ground? Now could you do the same thing, but moving the speaker grounds to the PCB ground point?
I would do this, but I'm SPICE-challenged.😀
