Hypex Ncore
who was it that said they had the instructions for adjusting the protections? Could you post them. Is it the previously unidentified pot on the amp?
Alan
I remember those posts, it wasn't too long ago, maybe 2 or 3 weeks back.
I'm still curious what that third pot does. The two pots for the input and output dc offset weren't adjusted on mine so i've always wondered what the third was and wondered if it needed to be adjusted as well.
As I only need RCA-XLR cables temporarly until I buy a surround processor with balanced out (maybe the Emotiva XMC-1) I didn't spend too much money on these I bought these one:
Procab CAB701 2x XLR male - 2x RCA male 1.50 meter kopen? | Goedkope | Promo | XLR - RCA
I don't know if this shop also delivers too Greece but you could look for the following cable PROCAB CAB701. Link: ProCab - 701
Get some ordinary xlr-f to xlr-m cables
and also get some separate xlr to rca adapters eg.
XGA32 - XCALIBER - ADAPTOR, XLR PLUG TO PHONO PLUG | CPC
Thanks guys, I found cables in two guitar shops where I live that seem of good quality, I will go with one of those.
It is not the third pot which is used for the protection calibration. I had the same dropout problems and with the help of Hypex got it sorted out.
First DC calibration with pot1 and pot2 as described earlier, then calibration of protection:
I think it is best to contact hypex directly as to avoid any problem of warranty if you do something wrong based on information given here. But basically you need to deconnect completely your ncore (no input, no output, no smps or other supply) and apply 3V DC to the 5-pin programming header of the PCB for a second or so (pin 1-, pin 2+, where pin 1 is the one closest to the red capacitors). For one of the amp is went ok immediately, for the other one I had to try several times (you need to plug in the ncore again and try if it works. If not you need to start again and I did it with slightly different voltage until 3.09V worked).
For the moment, no dropouts anymore (keep fingers crossed)
As for sound: 🙂🙂🙂🙂🙂
Seems these miss or uncalibrated modules are becoming more common...These seem to be marketed as plug together and play- not everyone has oscilloscopes and variable voltage power supplies for diagnostics...I hope Hypex keeps their eyes on the road and takes better care of the QC going forward or their brilliant product is going to have a bumpy ride....
Mockup photos:
I still have to sort the LEDs out (I have to experiment with LEDs and resistors), will be making a shielded internal mains cable and routing it properly, will be making different internal speaker cables and also making up shorter SMPS to NCore wires.
Mockup photos:
Looks very nice. Certainly easier working with wood than metal. So you think you will have sufficient heat dissipation with the amp module simply mounted to wood?
Though it isn't good that adjustments have had to be made I have to say that Hypex have been very helpful. I emailed them late last night and had a response first thing this morning and resolved the problem in minutes. I am pleased that Hypex make these available to DIY'ers like myself and that they're pretty easy to set up. I certainly wouldn't be spending the money they cost already built by a manufacturer as I couldn't justify it over other things.
I think your main problem is that you didn't use the power supply they're designed to be used with and I guess they have to prioritise their support to OEM buyers who are placing large orders.
I would not need support at all if they had been ok ! The support was good no doubt about that.
If you twist the cable tightly as suggested by Bruno, they will be shorter and probably at the right length for your outlay.
I'm pretty sure it will still be longer. I have the bits to make them up anyway but I guess it's hard to judge how much shorter twisting will make them without trying so I'll give it a go just in case.
I now have the LEDs and resistors worked out. Improved speaker cables and mains cables to go.
