Best "Vintage" Stereo Pres that SoftClip and lotsa Harmonics
hi all (newb here).
this is a research question BEFORE i build (my tech builds it) my next Tube Pre (12A_7 family or 6EU7 types) .
--what are some opinions on best vintage tube preamp ckts (1950s-60s, not modern) that give a lush, high in 2nd order harmonic sound (vs dull, or odd harmonics, or clean as in wont soft clip) that soft clips easily. this is for 2 channel preamp for audio (vs guitar, inst).
my tech and i have experimented w several CATHODDE FOLLOWER ckts. IMO , these are the opposite of the sound i want (not knocking it, but i want Thick, Rich and full of Soft Clip and Harmonix-these are relatively Clean !).
As well as NON- Feeback type units (similarly , not what i like).
Can someone point me as to what TYPE or specific ckt's are the opposite of the above and also opposite in behaviour (as noted above - thick, rich vs clean and wont soft clip) so i can know what to look for (what Type or What Schematic) to send my tech in right direction (hes a Great Tech , but has only been working w Tubes for 3-4 years).
Mostly this should be OLD, SIMPLE ckts (1-2 tubes) prob in White Papers or RCA Tube Manual from era noted above .
Example: Many "crappy" (ie: Silvertone-Sears, other Lo-End HiFi from then) Pre's ive heard from (late 1950s-1965) Stereo Consoles (tube) do this Sound well-but WHAT type (ckt) are they ?
I am pretty sure they are not Feedback and Cathode Follower types.
Thanks for any help - i need YOUR EXPERIENCED assistance as its getting Expensive to guess>build>then "no thats not it".
Again-THANKS !!!
Disabled Account
Joined 2004
Maybe you're looking for a preamp with a high output impedance. That should be easy for your tech. Also your tech could install variable resistors at the plate and cathode of the tube, with a little bit of tweaking you should be able to find your sound.
K - Thanks. Have tried the Plate Starving and get some results but not much. Could be not enough, the B+ is @ 285v and in my current unit the Plate , B+ is tied in w a pair of Line Lev Output transformers so the WHOLE B+ drops to drop the plate (only 30v). Maybe should be WAY more?
Will see about under doing the PS on the next unit - thats prob part of it.
What can i do so the Tubes are at "less than optimal " working points (or is that the same as Plate Starving) ?
Thanks!
Anymore ideas anyone ?
Disabled Account
Joined 2004
Well, I know you have tried cathode followers with no good results but you haven't tried messed up cathode followers. This schematic is a Jadis preamp, don't remember its name. I haven't listened to this circuit but have read some funny comments about it. I still remember one user's remark: sounds like a drunk Frenchman. Is that what you looking for? lol If you become desperate try the 12au7.
Goto Spice and the art of preamplifier design, Part 2 and build the LINE AMPLIFIER PURIST MOD. You can play around with a 500k pot wired as a rheostat in series with a 220uf cap to shunt audio signal to ground in parallel with C3C to vary the total gain. More gain, more rounded sound. Use carbon composition resistors and you will have a nice, complex, rich sounding unit. Change the output tube to a 12au7, lower R6C to 27k2w for more output drive if you want.
BTW this topology is based on the Merantz 7. Hovland used it on the HP100. I used it to make the GrooveTubes Ditto Box.
Goto Spice and the art of preamplifier design, Part 2 and build the LINE AMPLIFIER PURIST MOD. You can play around with a 500k pot wired as a rheostat in series with a 220uf cap to shunt audio signal to ground in parallel with C3C to vary the total gain. More gain, more rounded sound. Use carbon composition resistors and you will have a nice, complex, rich sounding unit. Change the output tube to a 12au7, lower R6C to 27k3w for more output drive if you want.
Wow - thanks for the details and tips !!!!:D
Here ya' go! Sorry it took sooooooo long I was really busy. This is the schematic to the GrooveTubes Ditto Box. When you turn the gain up it has a squishy sound like analog tape compression. There is a schematic floating around out there for "The Brick". That design was started by me but I left GT before it was finished. Mitch Margolis finished it and changed things to follow his design protocols. I never listened to a final production Brick so I can't comment on what his changes did to the sound.
btw, this unit will run fine with a pot in place of the output transformer.
Disabled Account
Joined 2004
Thanks... whats the "messed up" quality to the ckt ?
So, theres a Discussion somewhere on it ?
I don't know about messed up qualities* but I can tell you that the value of the cathode resistor is too low. Strange. Maybe the one who draw the schematic made a mistake -deliberate or not.
There's always some discussion on the net about almost anything. This one happened long ago so I don't remember the details.
Here ya' go!
Hey morinix thanks for the schematic.
*(On second thought I think I know a lot about messed up qualities)
