Hey there,
I'm looking for a 6.5inch woofer/subwoofer driver at the moment for 3.6L sealed enclosure (with active eq). I have tried TB, Peerless/Tymphany, Wavecor, Monacor and a few others with nothing has fit the bill so far.
I was wondering if any of you can recommend a manufacturer I haven't tried yet? Looking for something in the $10-$20 price range (250-1000 of). Stamped steel basket, ferrite magnet, rubber surround, paper cone with fs around 40hz, 85-90db efficiency and decent xmax over 4mm. Nothing special really, just a solid simple driver. Oh, and in 4 ohms!
Let me know if you can help! Cheers
Aurasound NS6-255-4A 6" Paper Cone Woofer 4 ohm: Madisound Speaker Store
Fs is irrelevant without specifying Qts and Vas.
Real bass sensitivity of the above seems 84dB/W.
In 3.6L : (optimum stuffing = 5L))
Q= ~ 1.0, 1 dB peak at 160Hz, F-3dB 100Hz.
Some low bass active EQ will definitely be needed.
Numbers are consistent with efficiency / box size.
It is a bass/mid rather than a sub/bass. Excursion
is good but with with a near equal coil / gap length
you'll get more distortion than long coil / short gap,
but you don't get the hard distortion characteristic
the latter has when its overdriven. It might suit.
$6.50 each for 90+, very good driver at that price.
rgds, sreten.
FWIW the 8" version which is a genuine subwoofer works
a lot better in the same box, Q= 0.75, - 3dB at 80Hz, with
good +/- 5mm linear excursion and a whopping overall
excursion capability of well over +/- 10mm.
Lower sensitivity though.
http://www.madisoundspeakerstore.com/approx-8-woofers/aurasound-ns8-385-4a-8-woofer/
$15 each for 8+, again very good driver at that price.
rgds, sreten.
You missed out on a Parts Express factory buyout 6.5" that fit your requirements pretty nicely (299-114), I used them in my travel trailer, sound quite good. Others have used them in a wide variety of cabinets.Surely some of you must know of a manufacturer I haven't tried yet?
PE has some other 6.5" speakers that may work for you, but at a higher price.
Woofer Selection Guide at Parts Express
Tang Band and Peerless would be the likely suspects, but you say those are not what you are looking for.
sreten: Yes I've looked at that Aura driver, fs is too high. It sims with a Fsc of 143hz. almost 5db down at 60hz from my current favourite
weltersys: We saw those and bought 10.... however they turned out to be rubbish and distort as soon as you drive them with more than 15W. I think the xmax figure is wrong and it is actually 3mm. they are identical looking to a Dayton Audio sub driver with 3mm xmax.
I'm currently using the TB W6-1139SA... it does great sub and xmax but the price too high and efficiency too low.
Optimal driver I have so far looked at is something like this:
Qts: 0.4
Vas: ~18L
Fs 39Hz
bl 9.1
Sd 131cm2
however xmax is only 3.75mm which limits output.
Thanks for the replies!
Qts: 0.4
Vas: ~18L
Fs 39Hz
bl 9.1
Sd 131cm2
Sorry, the Aura driver wasn't 5db down... more like 2.5db. It might be worth trying. What is the xmax?
but yes, perhaps best to state that I'm hoping for an enclosure fs of around 90-100hz and a q of 0.8-1.0
"efficiency too low"
Trying to break Hoffman's Iron Law?
Good luck.
A 2 cu ft 2nd order sealed box with an F3 of 30hz can only be 0.18% efficient (84.55dB).
A 2 cu ft 4th order vented box with an F3 of 30hz can only be 0.36% efficient (87.56dB).
A 2 cu ft 6th order vented box with an F3 of 30hz can only be 0.90% efficient (91.54dB).
By my calculations you could get -3dB at 120hz in 3.6L with 90dB/W/1M.
Good luck.
Good luck.
Not trying to do anything special, just choosing the right driver to optimise the response and use the amplifier power most efficiently. This is a battery powered sub so the location of the impedance peak is important to minimise the current/power for a given voltage
That sort of driver doesn't have clearly defined Xmax. One of Klippels
papers compares a equal coil / gap to a long coil / short gap. The
short version is the former produces at lot more distortion up to the
latters Xmax, but then the latter is worse above above its Xmax,
producing nasty higher order harmonics the former doesn't.
FWIW I think it was KEF that showed / argued the area with the
most energy demands on the bass is 100Hz to 200Hz. So I think
a somewhat higher Fbox than 100Hz would probably help a little
regarding battery life. Arguably the less than clean bass, could
also be an advantage, I've noticed for valve amplifiers mild
distortion makes bass lines easier to follow, YMMV.
rgds, sreten.
For a battery powered (portable) system, forget the bass below ~100Hz.
Go for a fairly high Q alignment (~1) so it sounds like there's some bass there, then add an active low cut filter at maybe the -6dB point.
Bump in bass response brings efficiency up a little, and the active highpass reduces amplifier demand.
Hoffman's Iron Law at work here: high efficiency, bass extension, small size - pick any two.
How much amplifier/battery will these be running with?
Chris
Chris
ahh yes... the missing fundamental thing.... can work well for battery powered devices. The now discontinued maxxbass 102 was a good implementation of this. Also porting at 100-120hz for a midbass bump, and high passing at around 80hz also gives some of this effect.
It also allows the use of high efficiency pa drivers, like the eminence alpha 6c. (the 4ohm version)
There's several nice scan-speak drivers that size with great performance and cast baskets, but you'd have to pay a lot lot more.
That's pretty much what my modded Bose Sounddock does - with a pair of 2.5" drivers, there's no chance of any real bass, but it sounds like there's plenty. Ran some frequencies through it, and there's nothing below 120Hz, but definitely a peak before the rolloff.
IMO, a 6" driver is too big for a truly portable (as in, throw it in a rucksack with some other stuff and go) system, and a decent 5" (or 4") should be used.
You'd get better bass response from such a small box, too.
Chris
Have you checked out alibaba.com? Harder to find the driver info, you'll have to contact the manufacter, but you'll be buying direct from the manufcaturer so the price will be much lower.
I saw these subwoofers on there before Car Power got hold of them and had them branded as their own: 300w ULTRA LONG STROKE 6.5" Competition Car Sub Kick Bass sub woofer ICE speaker | eBay
Fraction of the price that ebay has them for!
NEW Precision-Power MaxxBass Car Audio Equalizer - PPI Maxx Bass 41830 | eBay
"I saw these subwoofers on there before Car Power got hold of them and had them branded as their own"
±9mm x-max, ho-hum another major breakthrough!
The Tangband W6-1139SI is ±13mm.
I'm having a blast with the $8 299-114, I can't believe the way they sound.
I'm using multi-drivers though, in T-TQTW(S).
6-1/2" subwoofer with a deep profile, high-pulp, long fiber cone laminated with a protective coating that also dampens resonances. A hefty 1-1/2" dia 4-layer voice coil with 5/8" winding length provides long x-max/excursion, ensuring plenty of high-impact, low-distortion output. A bumped & vented pole piece reduces performance-robbing power compression & prevents "bottoming out" the long voice coil. Great subwoofer for multimedia systems, home theater, and multi-driver configurations. these are also PERFECT REPLACEMENTS FOR VEHICLE FACTORY ORIGINAL SUBWOOFER ENCLOSURES - EXACT 6 1/2" DIAMETER
Specifications
Model HOR6515
Nominal Impedance(ohms) 4
Power Handling RMS(Watts) 80
Power handling Peak(Watts) 160
Usable Frequency Range(Hz) 35-2000
Sensitivity(dB) 83.5
Voice Coil Diameter 1.5
Coil Former Aluminum
Magnet Composition Ceramic Ferrite
Core/Pole Details Bumped-Vented
Basket Material Stamped Steel
Cone Composition Laminated Paper
Surround Composition Rubber
Dust Cap Composition Laminated Paper
Net Weight 2.75
Shipping Weight 3.9
Thiele & Small Parameters
Resonant Frequency(fs) 38 Hz
DC Resistance(Re) 3.25
Coil Inductance(Le) 1.61 mH
Mechanical Q(Qms) 6.74
Electromagnetic Q(Qes) 0.64
Total Q(Qts) 0.59
Compliance Equiv Vol(Vas) .55 Ft3
Max Linear Excursion(Xmax) 4.5 mm +/-
Mounting Information
Sealed Eclosure 0.15-0.65 ft
Vented Enclosure 0.5-1.25
Overall Diameter 6.5
Bolt Circle Diameter 6.125
Baffle Hole Diameter 5.6875
Magnet Diameter 3.5
Depth 3.125
Mount Depth 2.875
$20 on eBAy, postage paid in the USA.
6 1/2" 6.5" Factory Subwoofer replacement 4 ohm 160W ford chevy chrysler jeep gm | eBay
Specifications
Model HOR6515
Net Weight 2.75
Shipping Weight 3.9
Total Q(Qts) 0.59
Magnet Diameter 3.5
Depth 3.125
Mount Depth 2.875
- Subwoofers
- 6.5in loudspeaker manufacturers
