LHC: New power record this week.
Yep, but it is not without concern. They have to watch the solder joints VERY closely, as they are running much closer to the cliff.. An interconnect quench may end up being non-reversible..the last time that happened, 50 ton magnets played leapfrog in the tunnel.
jn
I thought the design limit was like 11 or something. This shot was 8 bazziollion whatevers.
And to think I worry about blowing up a couple of output transistors.
I believe design was 7 Tev per ring, total of 14 Tev center of mass collisions.
The dipole current is about 13 kiloamps, it runs through a superconductor that is 600 mils wide by 70 mils thick. (15.3mm by 1.75 mm). If the conductor decides it is no longer a superconductor (quenches), the current density is a tad more than the copper jacket can withstand for long. So they have to be very careful, as it doesn't take long for a wire that size to exceed 1062 C (copper melting temp), or even 232C (tin/silver solder melt).
jn
... he concluded that, at the end of the journey, the time recorded by the moving clock was less than that recorded by the stationary clock. The result did not follow from the experiment, but was simply an assumption slipped in implicitly during the complicated procedure.
Sorry to say 7n7 that NIST has clocks now that can measure this in a 4 story elevator ride. The experiment can be repeated by anyone anytime, ad nauseum.
Which also supports Lorentz's and Larmor's theories, which I told you before. You didn't read enough of the references again.
jn,
wow. I love big machines, and the audacity necessary to build them. I did get to see inside the Advanced Light Source, LBL, Tiny by comparison, but gad what a machine and the history of what has been done there.
"ALSO" so please differentiate and eliminate ambiguity. I don't take Ivor Catt seriously if you do fine so be it.
Not sure if this has been said... 828 pages is too many to read.
The speed of light is a mathematical constant, so it cannot change by definition.
If for some strange reason electromagnet radiation takes more or less than 3.3ns or so to travel one metre, that does not change the speed of light, but will change how long 1 metre is.
Speed of light - Wikipedia, the free encyclopedia
Maybe there is some wisdom in USA not adopting the metric system ;-)
jn,
I never made it into the tunnel of the LHC, but did see the "leapfrog" players that were replaced. Man, those puppies are 45 feet long out of the cryostat. It's surprising what happens when the energy of a 747 travelling at 450 knots is released in a small confined area..
jn
I didn't realize that gravity probe A was launched in 1976 and started conceptually in the 60's. I was 13 and more interested in the Mars Viking landers but the clocks were good enough then.
Quite a difference in distance/cost, my point was it no longer takes a space journey and billions to get one answer that will always be questioned by the conspiracy theorists. The clocks now are six or seven orders of magnitude better so only a trip upstairs and back can do it.
I can't find the link now but it has been done, two clocks with sub femto-second stability were synchronized and one was sent up and down an elevator. The result was exactly as predicted.
I have heard of the elevator experiment also but don't remember when.
Very tough to argue against a conspiracy they just dig in harder.
For another example of measuring the gravitational effect on time, I may have posted this link before:
Project GREAT: General Relativity Einstein/Essen Anniversary Test
This is no high-fallutin' government lab - the experiment is accessible to anyone who has one or more HP5071 Cesium "primary frequency standards" laying around.
Thanks for the link. Just 33 cm to measure it.
Cool, it just keeps getting better. Pretty soon we'll have an Edmund Scientific DIY relativity kit.😀
I may have posted this link before as well:
Atomic clock oscillator module - ELEKTOR.com | Electronics: Microcontrollers Embedded Audio Digital Analogue Test Measurement
Now listening to DSOTM side 1. I may have also done this before.
$3000 for two is a little pricey, but a far cry from some of the research budgets.
- Member Areas
- The Lounge
- The speed of light is NOT constant
