buzz
one 6V3 winding is directly connected across 5U4's 5V heater !
does just one 6V3 winding have enough current for heating 5U4?
Just to be sure, you are saying wire the two 330V secondaries in series , not parallel, and common point between two taken to ground.Do this and you should have no hum. Your 6.3V secondaries aren't strong enough and you parallel those I suppose.
buzz
I have both 6.3V secondaries in parallel to rectifier. Should be 6A. Antek generally under spec's their trafos, so even one should do, rated at 3A; although working too hard i would imagine.
I just saw what Salas wrote about weak windings ........
you canconnect them in parallel , but!! securing that each 6V3 winding have own fixed resistor ;
so determine those resistors by trial and correct , going from higher value , that way that they're paralleled at tube heater
than take your Ub from whatever side of rectifier tube's cathode , as Salas posted
Use one 3A 6.3VAC secondary with your CL60 is another way. Should suffice. If it goes a little under 5VAC is better for the 5U4G's lifespan.
THe resistors before parallel point being an attempt to balance draw and reduce hum, as hum is essentially a difference or imbalance in voltage?
even if that you have hum there (in heater circuit of rect. ) and you have it anyway - because you are heating it with 5V/60Hz hum in fact
Exactly!. Actually, my secondaries are rated for 4A, so I think Salas is right that one can be eliminated, leaving the balancing act for another day. I ahev read that unused secondaries should be connected through a resistor to ground to prevent buildup. Am i delusional or is this something that is done?
even if that you have hum there (in heater circuit of rect. ) and you have it anyway - because you are heating it with 5V/60Hz hum in fact.... fact is that that hum is floating , referencing to your audio power circuit
Never thought about it like that.
Exactly!. Actually, my secondaries are rated for 4A, so I think Salas is right that one can be eliminated, leaving the balancing act for another day....
if they're 4A , then OK
........ I ahev read that unused secondaries should be connected through a resistor to ground to prevent buildup. Am i delusional or is this something that is done?
no
just isolate ends
just another web legend , at least in this case
even in digital world , fully open unconnected winding is - nonexistent
just another proof that Ground is state of mind
it can be whatever you choose , and execute correctly
well , you made probably all possible PSU mistakes .........
you can be proud of that fact itself
once you have full wave rectification (as I drew) , there will be no hum
It is veeeeeery quiet now😀. The class dunce thanks you both. Still bright oddly enough. Gonna give it some time, new caps in psu and all. After listening for a while, i see how silver and oil sound on output, although i have heard bright used in desscibing them.
- Tubes / Valves
- 6V6 line preamp
