ALPS Potentiometer with 4 Terminals
Hello to all the Members,
Here is a Potentiometer which i Intend to use as a Volume control for my Pre-Amp based on LM1036 Chip. It is a 50K ALPS Motorized pot, since it has four terminals, it is unusually strange for me because i got my hands on such type of POT for the first time
I have attached the pictures of the Motorized POT with this post.
Now to the Trouble, When i use a Usual 50K Pot (The one beside the ALPS pot in the picture), the volume control seems to work fine, the sound level gradually rises as i rotate the Pot control. However now when i replace the usual pot to ALPS pot, the volume control acts differently in such a manner that until 50% rotation of the ALPS POT there is No Sound at all, the sound level rises gradually only after 50% rotation of the pot. I dont Understand why this would happen even though both of the Pots are of the same value (50K).
The connections i do on the ALPS pot is same as i do on the usual pot, about the fourth Pin, i keep it Disconnected.
I will deeply appreciate any Kind of Help.
Thank you & Best Regards,
SLAK
About one of the Pins Being a Loudness pin, That seems to be it. Either the Second one from the Left or the the first one from the right, One of these pins is the Loudness Tap.
I tried this method, rotated the Pot Shaft to Half Way (50%) tried checking the resistance between any two pin to check for 22K-25K (50% of 50K), but unfortunately none of the two pins is giving such resistance. Really strange...
If your pot is an audio taper type, or logarithmic, you wouldn't expect the tap to show 50% resistance at the 50% rotational position. A better method is to turn the pot fully anti-clockwise (counter-clockwise) to represent minimum volume and see which two terminals give nearly zero resistance. One of these two terminals is the wiper. Now turn the pot fully in the other direction and check again. The pin in common with the two zero readings is the wiper.
If it was a Bal-pot it would almost certainly have a centre detent, the mechanism of which seems to be missing from you photo.
So it should be as per the attached pic and just ignore the tap
Are their any part numbers on the unit?
rgds
james
rgds
james
Hello, I have already tried this type of connection method as you have shown, but doesn't seem to work. The problem persists.
The part number is 50KAMX2, just cant find the datasheet anywhere
Unfortunately No, Until now i tried every thing, Tried different pin connection and lot more, Just cant get it to gradually increase the sound level as the rotation of the Pot shaft begins. The Sound level only tends to rise after half way rotation. 🙁(
It appears that you have connected the top end of the pot and the wiper pins correctly, but the audio ground is connected to the tap point in error. It should measure 50 kilohms between the top end and the ground end pins.
