Hi , I'm trying to work out a way to set up a good 12v system for my motorhome, I have been looking at a TP32 with usb DAC off my laptop and connected to a set of KEF IQ10's but im confused about the watts and ohms etc and if it is a 12v power adaptor as it states in the advert. Also if the amp will power the speakers correctly.. all help welcome.
So the speaker specs are:
Nominal impedance: 8 ohms
Amplifier Requirements: 10-100W
Frequency response: 50Hz to 40kHz +/-3.0dB
Sensitivity: 88dB at 1m for 2.83V
Maximum output: 108dB
United Kingdom - Explore KEF - iQ10, iQ30, iQ50, iQ60c, iQ70, iQ90
and the amp specs are:
TP32 parameters:
Amplifier output power: about 15W @ 4Ω, 10% THD + N; about 10W @ 8Ω, 10% THD + N
Amplifier Distortion: 0.03% THD + N @ 9W/4Ω
Amplifier chip efficiency: 81% @ 15W, 4Ω; 90% @ 10W, 8Ω
1 x 12V Power Adapter (with Adapter Plug according to your country)
Topping TP32 T Amp Digital Amplifier+Headphone Amplifier+USB DAC Black | eBay
TP32 parameters:
Its mains to 12V adaptor, in a motorhome I assume
you'd drive it with directly with 12V. Your probably
better off just using a decent car head unit.
rgds, sreten.
I think i will go for a mains hook up - set up and a car head unit while on 12v, seems like the easiest option.
Back to the actuall question .. would this amp drive my IQ10's anyone ? I wanted to know if it will run direct from a 12v source but i guess the vendor might know that.
