Can 3" TB W3-593SF be Fonkenized?
ok the drivers are the W3-593SF,my bad with the height measurement....that is why they say measure twice cut once!!
and one last question before i go out and buy everything i need....
it is a little on the theoretical side...
what's the difference between the fonkens,frugal horns,needles enclosures etc that use the same driver?
is it right to say better sound from one enclosure to the other?
or all have their pros and cons?
or it is personal preference in sound?
or it depends on the use one wants them for?(book shelf,floor standers,home theater use,presence of a woofer etc)
thanks ilias
Hi Proofring, about the theory.
Different desings have different shapes and volume. They also have different tuning frequency, which has to correspond to the data of the driver (Fs and Qts). Damping can also be different.
Which one is best ? This is very much up to your own personal taste.
I use MJK´s software to find the solution that suits my personal preferences, which is a flat frequence response and a well controlled bass. You can see some predictions in my document.
coolcat.dk/bjoern/TABAQ_TL_for_TB.pdf
okay the time has come for me to make my cabs...
i have one last question....how do i achieve the mirror like finish?they will be yellow i think,but i don't want texture (or as less as possible)
thanks
ilias
I'm not the expert on this but when I did a shop class, we put primer and sanded it down with finer and finer sandpaper to get the surface real smooth. And I know from experience when you apply spray paint to keep the can far enough to avoid causing drips (and also applying one light coat at a time).
