UCD 25 watts to 1200 watts using 2 mosfets
They are better for EMI.Unless you have complete enclosed gapped ferite inductor(wires not visible outside) which is better you must try those.
Wrong you are , if the gap is only in the center leg , the EMI is shielded by the winding, ye it'll be hotter , but EMI will be reduced.
In ferrite the EMI is emitted only from the gap.
And the ironpowder core emite all way round due to the microgaps of the powder.
P.S. In DIY nobody bothers about EMI , so and I.:cool:
Ok..i will do some further research on that:confused:..but what i know is that EI/EE/ETD ferite or will have much more EMI than iron powder toroids..
You will care alot about emi when after starting your amplifier you will lose all radio reception:D...for me a portable radio half a meter from the amplifier has to work normaly.Also emi from inductor increases THD and IMD..so is very important for diy segment also.
Emi from the inductor wires..yes...i though alot how to shield the inductor and made several experiments but without good results....the ones you posted i never tried..maybe in the next version..
Emi from the speaker wires can be reduced also by using an additional low pass filter after the amplifier.
PQ are hard to get ,
From the RM14 you can easily make a 30uH 40Amp inductor
