ECC82/12AU7 Line Preamp
Hi All
ECC82/12AU7 is like a Cinderella between tubes, as a simple exercice I sim an SRPP Line preamp and the result is, at least, unexpected.
It seems to me that we can drive an 845 whith this modest circuit.
Cheers :cheers:
If you look at how a 12AU7 mu varies with plate voltage, the seemingly nutty idea of putting 320V across it starts making sense. I suspect the actual results won't look much like the sim- even with operation on the flatter part of mu vs Vp, there will be a lot of higher order harmonics. But if you're going to extract the most out of a tube with poor linearity, you have to take extreme measures.
Of course, you could get better performance with a different tube and different circuit and not deal with 650V supplies, but that's not a polite thing to say. :D
Yes, the 12AU7 is a reasonable approximation to a square-law device over part of its characteristic so OK for LTP or cathode-coupled amp (so-called 'grounded grid') where the 2nd gets balanced out. Not so good for SRPP. The plot shows 2nd only. 2nd harmonic OK, 2nd IM not so nice.
During start up one triode could get 650V for a while, so scope for flashover?
Yes, electron cloud effect, that's one reason for tetrode and pentode invention.
The electrons between cathode and anode disturb the pass of new electrons.
Charges with same sign tend to repel each other.
I had seen that many times in the lab, didn't you made Thermionic Effect experiment, or measure the Planck constant?
I'm not sure if by 'electron cloud' you mean space charge. If so, it was not the reason for inventing the tetrode/pentode. The tetrode gives more gain, especially at higher frequencies, by shielding the potential on the anode from the electron stream.
I hope you are not running the triodes with sufficiently high voltage and current that it overcomes the cathode space charge. This will create noise and shorten valve life.
Hi DF96
Yes, electron cloud effect is the same as space charge, if you have problems with this, add another grid (tetrode) or elevate +B, if you still have problems add another grid (pentode) or elevate +B and so on.
Electrons that aren't absorbed by anode cotributes to space charge, in my childhood I read that one reason for tetrodes/pentodes was the space charge.
I'm sorry if I'm wrong.
Space Charge Tubes is irrelevant. Space charge in ordinary tubes is good, not a problem. It reduces shot noise (Google space charge shot noise smoothing) and protects the cathode from ion bombardment (Google temperature-limited operation cathode poisoning). You certainly don't want to eliminate it.
The transition from tetrode to pentode has nothing to do with eliminating space charge effects. It is all about eliminating secondary emissions effects - the tetrode kink. Some tetrodes deliberately use a space charge to achieve the same result. I think you have been reading the wrong books/websites.
Hi DF96
Exactly, that's the same I say in post #13, in your expertise words the effect is called secondary emission and increase space charge.
Space charge is almost impossible to eliminate, so I only try to minimize them.
It's true, space charge in a tetrode prevent secondary emission, but isn't so effective, so you need a pentode.
It seems to me you never done thermionic emission experiment, neither measurement of Planck constant and fight with space charge.
And yes, you are right, you are the genius physicist and I'm the stupid from the third world.
I don't know why you ever criticize all my posts, even if I'm right, may be I live in Argentina? or you are critic by hobby?
It's very difficult to obtain a good advise from you.
Came on, we are at the same planet, and at the same magnificent forum, dont ruin them.
No valid reason to eliminate it, as I said. Space charge is good.
Comments like that are too silly to answer. I hadn't noticed what country you are from; it is irrelevant.
If you are saying that you would prefer not to have your misconceptions corrected then that is fine. Most people on here like to learn, including me.
Hi DF96
I always thank you for your corrections, you can't say the otherwise.
Your critics are anoying, but make me think and this is good.
Isn't Landau-Lifshitz or Cohen, but can be useful
Electron-cloud effect - Wikipedia, the free encyclopedia
Space charge - Wikipedia, the free encyclopedia
Tetrode - Wikipedia, the free encyclopedia
Is an error suppose that space charge boundary is the grid.
When I measured Planck constant was a dicovery for me how much anoying space charge can be.
If not controlled can distort seriously a straight-line.
I can to look for the paper (It's in spanish) if you wish.
Without Child-Langmuir I knew the reason for nonlinearity in valves at Quantum levels. Planck constant is very little.
Wikipedia tells me that electron cloud effect is something which happens in particle accelerators, not thermionic valves, so this appears to be irrelevant.
Space charge around the cathode does not create distortion, it reduces noise and protects the cathode. It is an essential part of normal valve operation, as I keep saying.
I don't know why you keep mentioning Planck and quantum physics.
There are small numbers which matter: electron charge and Boltzmann's constant. If these were bigger valves would be noiser, but distortion would be unaffected
Wikipedia! Come on now....thats your reference source? A library of stuff cobbled together by the mass public....
There are better references out there than Wiki...
Do a little digging a little deeper than Wiki and you wil find that what Popillin is saying is correct. But, again i dont think to guys are too far off the same point.
Basically space charge and electron cloud are the same thing. How can you deny that distortion is not related to linearity in valves?
