At those prices + shipping to the US, I would think it better to your own case .. DIY ... look at that...🙂
Yup, they are not cheap, but i quoted the front/rear aluminum panels vs steal. Without the 10MM front panel and aluminum rear panel, they are $175 for the 400mm, and there's other options you can see on their website.
Par-metal is a less-expensive option, but wasn't able to get a good picture on how the heat-sinks attached to the chassis so I passed on them. They offer different heatsinks, which might be benifical and from the pictures you do see, they look more solid than HiFi's offering for the large chassis.
I did consider using Front Panel Express with Heatsink USA's heatsinks, but the total cost is higher with the FPE panels as each cut is costly. Cutting the vents for the covers greatly increases the cost to where I felt HiFi as a better starting point. I have used them for the rear plates, but nothing a drill press can't solve.
Sure you can scrounge for chassis parts and build something even cheaper or fabricate your own panels, but the investment in tools and time might not be something everyone would want to do.
My initial plan was to build an F5, BA3 and later added AJX, and now I have the F5V3 to toss in the mix 🙂 ...
@AudioSan
you didn't need to quote entire pic
those are smooth fins
amp was made for my Baby Diya forum pal ...
heatsinks are expensive and heavy and expensive to shipp.
Conrad MF18 & Modushop 10mm front panel, group orgy.
@AudioSan
hehe😀😀 i was aking about something on the pic
but it is modu chassis?
that can work🙂 if we put togeter a drawing for 2-3 diffrent type of chassis🙂
........ group orgy.
knowing you , you don't need Mr. Conrad and Missus Modu , for same ....
A couple of year ago there was a Conrad group buy and I think the price was around $90 or so for a pair. Doesn't seem bad.
ABOUT HIFI 2000
Matter of taste.
For monoblocks, for instance, you finish with huge empty boxes when all that room in the middle can be used by larger finns heatsinks ending as less tall and more efficient cases.
As for that bottom plate you'll have to rework.
As for thin back plates.
Matter of taste.
i had 2 chassis from them. and non of them had smooth fins🙂
maybe the have changed this some time.
ABOUT HIFI 2000
Matter of taste.
the "emty" space depends very much on your PSU. i have never had any problem filling up the space😀
(Me &) Missus Mo (gotta thing going on)
I'm on the Modushop front panel frequent flyer program, not worth the DIY labor for most stuff. (in particularE if order big, me 1-man orgy)
ABOUT HIFI 2000
Matter of taste.
some pics : Babelfish J za hifish-a - diyaudio.rs
take a good look at tech. bottom plate - that shiny perforated thingy ;
much stiffer than black bottom/top ones
in any case - they give option ( more greenies !) for Al top/bottom & back plates .....
Good to know the shiny perforated thingy is stronger than the bottom/top ones. Does it flex at all with that extra lip? I don't see the base panel for the 500mm depth chassis.
its only the transformer that has any weight. and you can mount that on a piece of 5mm alu plate.
- F5 Turbo Circuit Boards
