i am working on a sansui stereo amp au-4400 which has one chan dead. the faulty channel has the output rail grounded when it should have 28v. i have reverse engineered the schematic but am having a hard time locating the fault. anybody to assist!!!
Use the working channel to get a series of test point voltages,
and check the non-working channel against these.
Try interchanging the output devices between channels.
🙂 sreten.
🙂 sreten.
Good info on amplifier repairing:
http://sound.westhost.com/troubleshooting.htm
http://margo.student.utwente.nl/el/audio/amphelp.htm
Also try the 'Exclusively Sansui' forum at audiokarma.org:
http://www.audiokarma.org/forums/forumdisplay.php?forumid=39
I am searching for the AU-4400 service manual as well and wondering if you had any luck in your search.
Thanks!
