Laaaarge Heatsinks
This is a large heatsink with cross section size of 300mm x 50mm. The base thickness is 10mm, easly beat most of other heatsinks you can find on the web. If you are looking for HS for class-A, this is second to none.
The standard height are 85mm/115mm/125mm/145mm. Custom height are also available.
Price example: 115mm height type, $40/pc, weight 1.7kg, will takes $25 for air+ground shipping to USA or $30 to Europe:mad:
Shipping 2 or more will save a lot shipping costs. Hope somebody can start up group buy of such heavy products.
