subwoofers in the ceiling?
I'm starting to think about mounting a flat screen on the wall, and along with that in-wall speakers.
Then my sub is kinda in the way. Now, a 16" stud wall has over 3 cubic feet per stud, so if I rebuilt the wall to be sturdy I could just mount drivers in the wall. But it's hard to find shallow drivers to work well with that, and I'd end with a LOT of grilles in the wall.
So I started thinking of mounting subs up in the ceiling with some kind of HVAC looking grilles. Probably have to be back-boxed, to not propagate sound all over the house through the open crawl-space attic.
Also kinda thinking that if I had two next to each other right up next to the TV wall (and in the middle of that wall), they would load each other into like 1/8 space (???). A big issue I have is the room is open to a hallway and an adjacent den -> there's no corner for a sub(s).
Whaddaya think?
This was a group project on another thread....I'm really having fun with them (and they are not expensive).
This last build (out of 3) would be perfect for a ceiling install.
Now that you mention it.....I could do a ceiling install here!
I wouldn't want to cut up a floor 😱 when G.W.B. was an option.
With a pair of 2x4 cross braces at the bottom and additional stabilizing braces at the top, I don't see how anything would fall.
On another note, you'll want to keep the sub amp close to the speaker(s), i.e. keep the power feed cables short as possible.
I guess the real question is: can you "shoot" bass into a room? Or will half of it be left behind in the adjacent room, basement, or attic?
I tried subs that went thru the wall once at a friend's, it didn't work well (but I had too much foam in the boxes).
I have used sub in the ceiling in everything from Discos (Back in the day) to churches. A solid box is required for any decent sub. A plaster ceiling is often a fine surround. I would not use drop in ceiling tiles. If it is a drop in ceiling system then drywall may be used for the nearby panels. For WAF put the drywall on top of the existing tile. If you understand the acoustic absorption then you can see why that gives even more LF.
