I'll have to find out who did that.
No powercube is needed to see the whole picture.
Given that there is a large body of work on the subject going back to the 60's and before, do we really need to re-do it, your call though?
Looking at who makes them and what the drivers look like (look like french made or PRC OEM for that French harman shop), I suspect especially at 1KHz (where the woofer still handles the signal) there would be a lot of 3rd HD, even at 80dB.
If I guess the driver maker right you will have >0.6% 3rd HD at 85dB/1m (measured by K+T) and around 0.2% 2nd HD. At around 80dB due to the cubic law of 3rd HD may be down to around 0.1% as well as the 2nd Hd. Higher order stuff is mercifully low though.
So some of what you hear may in fact the result of combining a high distortion speaker with a high distortion amp. You may wish to crosscheck with inverted speaker polarity.
I think using a pair of headphones with known distortion performance AND with low distortion may be a better way.
Ciao T
I will do a test dedicated to even harmonics to have
some clues about it...
As for my speaker s HD content , i dont know since i ve no accurate enough microphone to perform a valuable measurement.
Ciao T
If memory serves, "medium SPL levels" in a room would be in the range of 85...90 dB, ref. 1 m, both speakers active.
The actual value will vary due to possible room sound treatment, furnishings and ambient noise.
According to some not very good SPL meters, it seems I use my speakers at around 87...88 dB SPL re 1 m. That would be my medium volume, but then, my room is small by any measure, just 12 m2, or about 130 ft2.
As for HK, I told you - load tolerance is their very strong point.
My 680, nominally 85/130W into 8/4 Ohms, whacked me with a peak power burst of 512 Watts into 2 Ohms. Since I don't spend my time listening to sine waves at full rated power, I reckon that's quite enough for most people, with most speakers, in most rooms.
I guess their HCC (High intstantaneous Current Capability) is not just an ad departement catchphrase, rather a piece of Otala legacy.
Recommendations for listening levels vary somewhat. In germany for studio's we often see 94dB SPL for a -14dBFS (or 0dB VU). That means a "loud" but not excessively compressed CD will generate 94dB average SPL during the loudest passages, giving 111dB Peaks at 0dBFS.
Incidentally, the 94dB match well with SPL measurements I undertook at the Royal Festival Hall for an orchestra at ffff while playing "big" music (Mahler, Mussosky/Ravel etc.) at around 6th row centre.
I have seen similar practices of level (give or take a few dB) elsewhere, THX recommends 108dB peaks for 0dBFS (85dB plus 20dB headroom and 3dB correction for peaks).
Sadly many commercial music recording studio's do not adhere to such a convention, which usually makes their mixes less portable than ones from studio's that stick close to "best practice" for monitoring levels.
If listening levels are much lower than these references we would have to apply physiological frequency response correction, that is some bass boost. This boost is often build permanently into "audiophile" speakers under the misguided concept of "baffle step correction". Such speakers sound overly bass heavy (I usually call the bass produced "Stunt Bass") when played at realistic/reference levels (assuming they can reach them without gross distortion). But that is a whole other kettle of fish.
Ciao T
Ciao T
Shhh, don't tell a.wayne, he will say your amplifier is no good if it's not "flat".
He prefers a linear solution to reproduce non-linearity.
Ciao T
That such test were already done doesnt make them useless ,
quite the contrary.
As for the speakers , right that the fundamental is rendered
by the woofer , but H2 fall on the crossover point while H3 and above
are in the range of the tweeter.
Dont know for the woofer , seems its marking was removed ,
i ll check later , but it s surely not a low cost OEM thingy,
while the tweeter is a Morel MDT30.
As you point it , increasing the amp output level
will increase its THD as well as the one of the speakers ,
but then , theses latters were driven at low level so the
figure of 0.6% at 85db SPL is rather unlikely.
Well, let's see. A number of test have been done with better instrumentation, methodology and controls and thus they do not make casual tests with worse instrumentation, methodology and without controls useless? I don't know, I'd likely argue that they in fact do.
And yet the fundamental applied to the woofer will give rise to H2 and H3 in the woofer where it will mix with the amplifiers HD and will not generate higher order products.
The woofer looks to me like an OEM version of the common Audax Drivers, though I'd have to see the back. They are fairly common in british made monitors (see Soundcraft Zero series among others) as are Focal. Sadly Audax and Focal share the same magnet system design and that is one that is very high in distortion, compared for example to skandinavian drivers.
Audax did do some very advanced work on cones for drivers (their Carbon Fibre driver can for example be run completely open (no filter), but their magnet systems are very poor, leading to drivers with relatively speaking very high distortion.
If the Bass Driver is indeed Audax, then the 0.6% H3 figure for 85dB/1m is correct, it is a feature of all their woofers, my figure comes from measurements by the German magazine Klang + Ton, where for example H2, H3 and H5 measurements are published for each and every driver tested (also waterfalls etc.
I did remark as you where at lower SPL's the 3rd and 2nd order HD of the speaker was likely reduced to around 0.1% each in your tests.
At any extent, I think you should seriously test your speakers first to see what distortion levels you are actually getting.
Linkwitz modified Panasonic (or Transound) Electret Capsules have low enough HD at these low levels to measure serious problems in Speakers, such as with the Focal/Audax woofers.
Ciao T
That such test were already done doesnt make them useless, quite the contrary.
As for the speakers , right that the fundamental is rendered by the woofer , but H2 fall on the crossover point while H3 and above are in the range of the tweeter.
Dont know for the woofer , seems its marking was removed , i ll check later , but it s surely not a low cost OEM thingy, while the tweeter is a Morel MDT30.
the speakers, but then , theses latters were driven at low level so the figure of 0.6% at 85db SPL is rather unlikely.
Ciao T
Well, you can argue all you like, but I'm happy with my Audax based speakers. The bass and mid have cones made of their take on the aerogel membranes, while the tweeter is their top of the (in its time) TWO25A16.
I'm not sure what you mean by poor magnetic assemblies, Thorsten, but my woofer has a magnet of 3.4 kilos, mounted on a die cast chassis. I wouldn't call that naive, especially after you hear it reproduce the strike of the 8 foot drum on the Blue Man group first CD - loud, clean and clear.
I'm with you, T. If people would read the harmonic distortion chapter in the 'Radiotron Designer's Handbook', from 1940 or so, they would have some clear info on distortion detection levels.
Not everything has to be tested for, over and over again.
For example, we know that loudspeakers generally have more distortion than the electronics that drives them. We debated this 40 years ago, but we still have found that amplifier distortion is audible, almost no matter how low it gets. This implies more subtle types of distortion, beyond conventional measurement equipment are being generated and passed through the loudspeakers to be detected by the ear. Two known measurements that fit this criterion are Hirata distortion, and PIM or FM distortion. This is where we should concentrate our efforts. I certainly have.
I am not arguing. I am merely observing that independent measurements have repeatedly shown Audax Drivers to have very high levels of distortion. There is no argument, just an observation.
Whatever floats your boat. But they have VERY HIGH levels of distortion. Again, no argument, merely observation.
The Aerogel Cones where in my view the less successful development by Audax, all with severe and nasty breakup, compared to the much more gentle and very well damped breakup of the woven carbon fibre units.
Not that it matters one iota where it comes to distortion, as the motor assemblies (voice coils, spiders, magnets etc.) are the same.
It means poor linearity, high and variable voice coil inductance and many other things that make speaker drivers have high distortion. I should have perhaps said "magnet assemblies of poor design". In fact, Audax drivers are text book case that allows one, should one want to, to illustrate each and every bad practice in speaker driver design that drives distortion up.
And what has that got to do with price of tea in china?
3.4Kg of magnet assembly that create poor linearity (and thus distortion) is as bad 1Kg or 10Kg of the same.
Ciao T
Ciao T
Since there s only four screws i dismonted the bass/medium driver.
It s built specificaly for Quested by Volt Loudspeakers.
The marking is BM220.7 Quested specs.
No trace of THD graph in their datasheet anyway for
current approaching models...
Volt Loudspeakers - Studio Range
Ah yes, Volt, they have such a low profile these days, I tend to forget about them.
The BM220 generally has good LF performance, but midrange distortion may also be a little on the high side.
Alas, no independent tests I know of either. So as one of our Dutch contributors has in his sig "To Measure is to Know".
As said, the Panasonic WM61 or the Transsound equivalent linkwitz modified is low enough HD to show up big problems.
Ciao T
Ciao T
Strictly as measuring mike.
In my case I actually have a Behringer ECM8000 which is the whole thing build into a measurement mike case. So someone else did the job for me. Otherwise check the Linkwitz site.
EMU 1616m or EMU0404USB external sound cards, also provide phantom power.
Not use it at all?
The WM61 does not make a good recording microphone IMNSHO.
Ciao T
How do you prefer to implement the WM61?
What are you using for a mic preamp?
What is your preference in regards to a stereo mic layout with the WM61?
Not use it at all?
Ciao T
My 680, nominally 85/130W into 8/4 Ohms, whacked me with a peak power burst of 512 Watts into 2 Ohms. Since I don't spend my time listening to sine waves at full rated power, I reckon that's quite enough for most people, with most speakers, in most rooms.E
Yes that HK990 is an serious all in one kit , price reflects it , would love to see sterophile and others incorporating the powercube test as well ...
I was in love with my amp and speakers too... till one day I did look to some headphones measurements and I realized some of them blew away my speakers. I did buy a pair of Grado SR60i just on a whim and now, they are my main stereo listening device.No trace of THD graph in their datasheet anyway for
I do use the speakers still for surround programs (from SACD, DVD-A), but when I have stereo sources... Grado's
Funny thing about Grado cans. I had read so much about them, seen the measurements and all. So I ordered a pair "sound unheard" off the Internet. Hated them! Thought they would rip holes in my ears. Tried everything that the seller suggested to make them sound better, but ended up returning them. He said it was the first pair he'd ever gotten back.
Did the measurements (and reputation) match the perceived sound quality? In my case - NO. In your case, it seems - Yes. Why the difference?
Ditto. Grado Can's. Make 'em go away.
I'm not hot 'can's anyway.
Ciao T
Ciao T
Maybe our ears/brains hear different? As I said, I was weary too about them. Got the SR60 because of the measured response, closer to my prefferences (better IMO even than SR325).
I do love the sound of pure metallic percussion (cymbals, top hat) and clear medium frequency response (voice, sax, trompets). Don't care for hyper bass response - and I know some people that use ONLY that as quality measure.
I guess is a matter of type of music and brain expectations too...
If your brain was used to a lower response in the high-freq part of spectrum, it is used to overcompensate the ear response to that region. Changing the headphones/speakrs to something that is more flat/linear in thar region, will increase the ear signal to the brain for the region. Brain is still over-compensating and mental result is "too bright". Listen a couple of days and your brain will adjust with the new stimulus. Some peopl ewill say that "they needed to be burned-in" - actually their brain needed to be retrained.
I guess only listening a live band can provide a "refference point". But in case of rock, that depends also of the mixing enginner for the live performance.
- Member Areas
- The Lounge
- Sound Quality Vs. Measurements
