Does anybody know where I can get a schematic for the LINX Nebula intergrated amp,as I'm having trouble with the 12v supply going down after about 15 mins of use,
any help would be much appreciated.
thanks malcolm
thanks malcolm
Wharfedale
I got one some years ago from Wharfedale - for some reason they had taken on support of linx equipment. I suspect you won't have much success with this line of enquiry though so if you like I'll have a go at scanning it in and attaching it to a message on this forum. It's a little bit blurry so you might not be able to read all the part numbers, but it'll be better than nothing I should think.
linx nebula
Hello, i have an linx nebula too, which has some defects. (with low volume the signal becomes distorted and is fading away) Would it be possible to send me the scanned schematics of the linx to my email: rene.erwa@chello.at.
thanks, greetings René
Hi:
I have another Linx Nebula, can you send me the scanned schematic, pfshepherd?
Thanks in advance
my e-mail: jcruizj@hotmail.com
Thanks in advance
Ooops - haven't been checking on this forum. If anyone still wants a (poor quality) image of the circuit diagram send me a private message with your email address. Also, let me know if your email server has a problem with large attachments and I'll split it into several emails.
In the attached PDF files my own created schematics from LINX model "Quasar" - perhaps helpful.
Who knows, who has overtaken this audio brand (resp. the currently brand name)?
Excellent! Thanks - how did you come to have these?
I have a photocopy of the Nebula circuit because I sent it for repair and asked for one. At that time Linx equipment was being serviced by Wharfedale. I am under the impression Linx has long since disappeared.
Linx Nebula saved!
Many thanks to Paul (pfshepherd) for emailing the schematic. I tracked down a shorted
2sc2910 in the 12v logic supply which when replaced brought the amp to life. 😀
The amp sounds pretty darn good - I bought it faulty so this is my first audition. I think it might be the best £15 I've ever spent! I think I even got a pair of bookshelf speakers with it iirc 😎
regards
David
regards
David
Hey everybody I need a schematic for an Linx Nebula Amp. So please mail it to my email: info@neumann-tv.com
thks
M. Neumann
thks
M. Neumann
Linx Nebulla
need also a copy from the circuit diagramm ...thanks
joachim-schneider-web@web.de
Many thanks to Paul (pfshepherd) for emailing the schematic. I tracked down a shorted2sc2910 in the 12v logic supply which when replaced brought the amp to life. 😀
regards
David
whoever is having one , please pass it to >sasica5@gmail.com<
having one for repair , but slightly abused by incompetent techie
Quasar is pretty close , but I simply cannot be sure how much close , because of pretty headless tweaks ....
Another kind request for the Linx Nebula schematic... Send it to:
gyongy.bela@freemail.hu
Thx.: Andrew
Thx.: Andrew
Hi pfshepherd if still available I would like a copy of the Linx Nebula schematic Please send to lindengraham225@gmail.comOoops - haven't been checking on this forum. If anyone still wants a (poor quality) image of the circuit diagram send me a private message with your email address. Also, let me know if your email server has a problem with large attachments and I'll split it into several emails.
Many thanks
Linden
Hello, do you still have the Nebula circuit drawing? i would like to ask you (or anyone who has it) to send it to me , please.
Thank you!
- Linx Nebula Schematic
