This may seem like a stupid question, but.....
Are there any boards/kits/schematics out there for single channel amps in the 10-15 watt range?
I am engaged in an ongoing project to convert my entire library to FLAC, to stream wirelessly with AirPlay dierectly to each set-up. As a first step, I am interested in converting a set of speakers to an active configuration, with on-board amps, and am looking for a solution other than running two t-amps with one channel fed to each half of the board.
Any suggestions would be warmly welcomed.
Thanks,
Robert
Thanks,
Robert
Glad you asked😀Hi,
I'm just about ready to have PCBs fabbed for something in that field.
It uses the TI TAS5727 chip in PBTL, meaning
15W into 4Ohm @12V single supply
38W into 4Ohm @18V single supply
The TAS5727 has digital input (i2S), soft limiter and a programmable DSP, interesting for speaker cabinet equalization etc. See here: Speaker Amplifier and Modulator - Mid/High-Power Amplifier - TAS5727 - TI.com
The board is meant to be used for distributed audio systems.
At higher supply voltages it can even serve a subwoofer IMO.
Here is a PCB render. If you're interested, I can have a few more built.
-E
