Hypex Ncore
earflappin: Thank you, thank you, thank you, thank you...
Not to highjack, but...I can't agree more how important it is to get everything else ideal to properly judge the Ncores...6Moons recently loved the Dutch b Audio DAC, and IIRC could hear no difference in direct AB vs. another favorite DAC 3x more costly. Guido (UH-doh) Tent, b Audio principal, is close with Bruno (I believe). My friend loved the Tent Labs Hypex-based amp with tube-input/transformer coupling (pre Ncore).
I very much liked the Eastern Electric mini-DAC (circa $1200 with op-amp upgrades, preferred vs. a $15k DAC), in direct AB with my modded CDP owned for 8 years (impossibly long time for me not to "upgrade").
I will order 3x Ncore and PS ASAP.
@Arthur I think it would take us off topic to discuss in detail. ESS's claims regarding the SRC pertain to the actual interpolation process. They have done an absolutely splendid job there. The thing that causes problems is the ratio estimator (the bit that works out exactly what sampling time to interpolate). The bandwidth is too high which lets through time quantization errors. The circuit samples the incoming clock signal using its reference clock. This results in the addition of jitter with a peak-to-peak value of one reference clock period (e.g. 25ns for a 40MHz reference clock). Next the number of ref clock periods in one input clock cycle are counted and this constantly changing number is fed into a low-pass filter which outputs a cleaned-up version of the ratio between the reference and input clocks. This ratio is then used to space the "virtual resampling points" calculated by the interpolator. Of course the low pass filter doesn't output pure DC. The spectrum of the counter output consists of mix products between the two clocks. The filter can only attenuate those. The attenuated spectrum shows up as close-in FM sidebands exactly like jitter. DNR and THD measurements ignore those. The SRC successfully removes high-frequency jitter, thus guaranteeing good SNR, but it adds low-frequency phase modulation of the signal that wasn't even present in the input clock. All SRC's do this but the bandwidth of the low-pass filter determines whether this is an issue or not.
The attached two measurements were made on a standalone test chip for the ESS SRC which was never issued as a product, but the actual SRC did go on to be used in the Sabre DAC.
But 120 dB down on the first lobe is nothing to sneeze at especially considering it is only a 50 buck chip !!
Considering that MSB tech conveniently choose not to provide distortion measurements it is abundantly clear that this 50 dollar "mass market" dac is vastly superior to this Hi-end megabuck goliath !!
When it comes to that: 6Moons scaled the Octave in the 5000 dollars class, and Martin Colloms (HiFi Critic) wrote:
No messing about, the score came out at an
incredible 185, which is true reference class, mixing
with audiophile devices at 15 times the price!
When you have the chance lend the Octave your ears....
pieter,
Thanks for the splendid DAC advice!
Best wishes to fellow Ncore pioneers! Any suggestions for chassis source welcome (3x Ncore channels). Can hardly contain my enthusiasm just learning the Hypex power supplies are complete, no transformer required. Christmas in February is good!
Metrum
I am reading the thread because I am interested in ncore (which I don't own yet 😀), however, I do have a Metrum Octave since two weeks. After reading the 6moons review and several other raving tests I expected this DAC to clearly outperform my 20 years old Marantz CD 16 Exclusive and my friends Rega DAC. It didn't for me (and a couple of friends). Sound is very lean and precise, however the music lacks "body" and... well, musicality. Especially the Rega DAC with its differend filters is clearly better in my ears. Going to give it back next week.
Sven
@Earflappin:
Great listening report, and I do agree with you completely. Interesting that you mention piano - to my ears good recordings of grand piano is where the Ncore really shows its strength. A friend of mine said that with my old UcD amps grand piano didn't sound "expensive" enough... meaning it sounded like a lesser quality piano. It sure sounds more expensive with the Ncore amps. 🙂
I also notice that everything sounds darker, warmer, smoother with the Ncore, but yet more spacious and with better resolution of every tiny musical detail.
Difficult to get some (for me at least) reliable reports for the time being apparently....
When bass in my system sounds "sensational" I probably stop listening after an hour or so....
I am sure that the amps sound very good, but how good amidst other well known good sounding amplifiers???
Not meant in a negative way, but please try to be a bit "subjectively objective" (should not be too difficult for a Norvegian 😉).
I have only three amps that I have tested recently on my monster bass towers (eight 21" woofers), so I can only comment on those:
1. ICEpower 1000ASP (same as the well regarded Bel Canto Ref1000)
2. Hypex UcD400HG with SMPS400
3. Hypex Ncore NC400 with SMPS600
The ICEpower is a very capable bass amp, no doubt. But the UcD400 sounds a bit fuller, with more tone and more punch. ICEpower sounds somewhat tighter/leaner without actually having any better resolution.
As I said before, I need some more listening on the Ncore, but the impressions so far is that it's a major improvement, primarily in definition and dynamics. Its noticably more punchy, faster and controlled than the other two amps. And the definition of tone is better, its easier to hear the pitch and tonal quality of low bass notes. A few examples: different bass guitars and players sounds more different than before. Its also easier to hear if a bass player is not playing each tone with the same loudness, the same goes for bass drum.
Yes maybe, but I trust my own ears enough, and don't need Bruno's advice on this one.
When this particular Dac wouldn't work with UCD (curious to know why...) I'd sooner replace the UCD than the Dac 😀😀
IMO there's a lot of audiophile BS out there but there's none worse than the filterless NOS DAC scam. I'm saying this from the position of someone who owns a NOS-modified CD player.
I guess everyone knows that some of the best audiophile recordings are produced using dCS pro equipment (not made anymore). have you ever seen the insides of those units? they resemble a PC motherboard more than an audio product. and yet, at the playback side of things one transistor too many ruins everything 🙂
my frank opinion is that it all comes down to $$$, not NOS vs OS. there's no such thing as a cheap DAC that's really good..
And that is before you have seen the innards of the typical studio mixer... 🙂
Earflappin thanks for the report.
You already own the nCore of DACs (absolute performance, no nonsense and "no sound of its own" manufacturer's attitude and value for money considered).
Bonus points for LIO's flexibility (not really applicable to power amps) which further differentiates your card/DAC from the competition at this and significantly higher price points.
@earflappin
May I ask you, which PSU arrangement are you using? The SMPS600?
Avr300, I am using 1 SMPS600 for both nCore400 modules. To implement this configuration you need to create a Y cable by cutting in half the cable provided with the SMPS600.
I will probably buy a second SMPS600 not because I need the power, but so that I can get the amps closer to my speakers. I will use a stereo case to hold open the option to either run active or biamp.
Speaking of cases, has anyone completed a design available for purchase?
BTW, Stig-Erik, thanks for your post. I found myself nodding my head in agreement as I read it.
