Mosfet Transistor question
I have two dead transistors IRFP9240 and IRF9610. I tested them and I am not getting any reading from them. Can I just replace them with new or do I have to replace all of them?
All of them but those two I am getting readings. I checked and rechecked just to make sure. It is my fault too. I recapped the amp and had two wires switches. Left channel works fine and the right blows fuses. I have been checking the values to everything on the board.
Thats what I will do. Thanks again.
It should fix it.
I usually find blown mosfets are all that is wrong.
I dont want to get too technical but sometimes something else can be taken out to further back in the circuit with the mosfets
If i replace the mosfets and they blow again I take out all the mosfets and wire the VAS output back into the ltp and this closes the loop for testing the amplifier. I can then check for dc bias and offset.
I wouldn't just replace those ones that are fried. They need to be matched- all of them. If you replace only the ones that are fried with diff production date ones, chances are that you will be sacrificing reliability. Also from experience, always desolder Mosfets when testing. For some reason they can test no-short when in circuit. Maybe someone can tell me why?
Im going to desolder them tonight and test. It sounds like a good place to start and I will probably order 8 new mosfets tonight. I ordered 2 yesterday, but was wondering about the matched issue. Im glad someone mentioned it. In the least, I will have two spares. Unfortunatly it takes forever to ship from china.
I replaced the suspected transistor, set the bias and the amp fired up. It does run hotter than normal, but sounds fine. I think I understand why they have to be replaced in series now. I think I am going to buy 12 matched from ebay. What is the tolorance to make them "matched"? Is 50mv alright?
Do they need to be matched ?
The bias (quiescent current in FET's) will determine how hot it runs. Have you followed a specific manufacturer procedure to reset it. Is the bias stable with temperature ? Have you rechecked and reset the bias when the amp is really hot ?
Replace all of them. Make sure the batch numbers on them match!! If the unit has source resistors, make sure they are matched too. Once everything is soldered in. measure across source resistors. They should all give the same voltage reading. If they are not, move mosfets around a bit to mix 'n match!!
