Hi Raj,
It will work with two pairs but the current will be limited to 14A. If you want to boost the rails you can but with modifications here and there. The posted schematic uses +/-40V with a rated output capability of 21A.
kind regards
H.
kind regards
H.
What are you driving with 21 amps? Rated means continuous, which is rms, what should the transformer rating be 2KVA, per amp?
Hi Raj,
kind regards
H.
Alright Harrison,
I will remain at +/-40Vdc. Its only for normal home listening.
Thank you and regards.
