You can check out this site headfishoip: Stereo Headphones, Headphones amp,Amps & DACs, DIY audio kti,Resistorsl,ELNA capacitor,nichicon capacitor Audio Cables & Accessories,cmc,tube you can get some parts here like the WM8741, DIR9001, ELNA silmic II caps, pcm2707, etc.
Forgot to mention the tracking numbers. The tracking numbers has been sent out to all orders.
Thanks!
Which company did you send them with?
Brgds
hi ,this dac is mono or stereo?
thanks
Hello, this is a stereo dac......Thanks
I also have a finished wm8741 upsampling super mini DAC from the previous version. If anyone interested can PM me. It will work on 7.5V regulated power supply. Power supply will not be included, buyers have to arrange for their own power supply.
This fully finished DAC of the previous version is not available any longer. It has been sold out.
The larger box under with the big volume knob - what might that one be, any details you want to share?
Brgds
That's a class d amplifier. My next project is going to be a class d amp and dac integrated together on a single board ES9018+TAS5630. Will post the screen shot ASAP.
Why combine them? IMO it is better if you create the best modular ES9012/18 DAC and a separate class D-amp which we can chose to use or not.
Brgds
I have already created the TAS5630 amp, its ready. ES9018 DAC, i am creating one right now. For the ES9018 I won't be able to release the circuit diagram because I am kind of restricted, i've signed an NDA . It can be easily assembled with the provided board layout for component placement. The reason why i thought of integrating both amp and dac together is you kind of have a nice all-in-one unit in one neat compact housing and cost effective. TAS can be driven differentially, so I thought of taking the balanced output from the ES9018 and drive the TAS differentially. For the volume control and the different settings we can use the open source arduino codes. But yes, still you will be able to switch off the amp unit if you don't want and can use the dac module alone. It is just an idea, I haven't done it yet......Thanks
- Group Buys
- High Performance WM8741 Upsampling DAC New Version - Group buy
