What about the Clarity Cap from the ESA range?
250vdc
+/- 3%
ClarityCap ESA range of capacitors home page
Will these fit?
250vdc
+/- 3%
Will these fit?
250vdc
+/- 3%
Will these fit?
Thanks data! it looks good, but it is 30x45mm and the Mundorf is 19x28mm
So 10uf?
And won't fit?
Hard when space is limited so much, I would have a hard time picking between the Mundorf and the Wima, I would lean towards the Mundorf but would need to try both for an extended time.
I'll let yo know If I think of a smaller cap that is good...
I guess 35x20 is cutting it close too?
http://www.diyhifisupply.com/node/733 Just throwing in an alternative
And won't fit?
What capacitance value do you need? And why such a high voltage rating?
Well, I just need around 100v 4.7uf. the original was Panasonic FC 4.7uf 50v.
- Design & Build
- Parts
- Recommendation input cap.
